Thinking of importing Patrol parts from Colombia??
Parts for sale, or free
Re: Thinking of importing Patrol parts from Colombia??
leidgam wrote:...
Also I brought in 2 sets of valve stems for the G60 but it looks to me like one set is different from the other. I'm attaching a picture: I have a full set of the valve seal on the left and another full set of the valve seal on the right; can somebody please advise if one set is wrong or if they are both the same?
Both look like the ones that should go there, but only measurements can tell. With the following measurements you can see which ones are a match.
The valves have a diameter of 8.64mm (0.34")
The valve guides a diameter of 15.03mm (0.592")
These measurements are from the Service Manual.
Has thanked: 38 times
Been thanked: 37 times
Post by leidgam »
rdarnell wrote:saw a gasket set on ebay the other day that is in concord NC, would that be you?
Yes sir, that would be us. We just listed it 2 or 3 days ago. We also have some other random Patrol parts listed you might have seen.
Been thanked: 1982 times
Hello Mag, I would be interested in modern bolt two barrel carburetor. There must be a modern solution that accomplishes the task better than the Rochester B, while the Hitachi VZ 42 is better, no parts.
Then, how about pre-65 and a post 65 Master Brake Cylinder.
Then, if we really want to dream a steering wheel gear box.
Regards,
Ok, I left off wiper motors, blades and arms for various year models.
