New to the Patrol world
Has thanked: 6021 times
Re: New to the Patrol world
Welcome to 60Patrol! :clap: :clap: :clap:
Your Patrol looks in good shape, and I'm sure that in no time you'll be enjoying it fully.
Great story about how you find it. If you have tackle engines before, the P engine of the Patrol will be absolutely doable for you. There's good chance that a lot of that smoke is due to lack of use.
Been thanked: 1989 times
Ok before auto correct got me again I meant to say,
" I bought three forklift starters. None worked fully, they were weak and dragged. I now have Eddy rebuild originals".
Having said that some more experienced crews/mechanics seem to be satisfied with them.
Patrolling with your parts,
Has thanked: 7716 times
Thanks for the pic of the ID plate. You're officially in the Registry. :D
Has thanked: 351 times
Been thanked: 301 times
Post by mdawg4x4 »
Has thanked: 264 times
Been thanked: 776 times
Post by plateaucal »
poinrobe wrote:Here are a few more pictures. I included one of the starter. It appears to be aftermarket. From my brief perusal of this forum, i thought that there were no aftermarket starter options. Does anyone know if this is correct. Given that this starter is frequently not engaging and thus making a grinding sound, do you think it is worth having it rebuilt?
I had that problem with my starter. It turned out to be a voltage drop on the solenoid due to a corroded connection as the fuse box. It did not have enough "juice" to pop in all the way or reliably. Might want to check that out.
Has thanked: 28 times
Been thanked: 31 times
Post by poinrobe »
So I have started on this project. I will be starting a rebuild thread but i have a quick Q for folks:
The Nissan Service manual indicates that this engine/transmission/transfer case should all be removed as one assembly. Is this correct? This seems logical given the difficultly accesssing the rear of the engine while it is still in the vehicle.
Thanks again for the help!
Yep, all in one fell swoop. Removing the front bib helps immensely. Have a heavy duty cherry picker because the unit weighs almost 1000 pounds.
Post by poinrobe »
RiverPatrol wrote:Yep, all in one fell swoop. Removing the front bib helps immensely. Have a heavy duty cherry picker because the unit weighs almost 1000 pounds.
Excellent. Radiator and front grill assembly have been removed. Now removing shift levers, hand brake etc. Hopefully will get the engine out this weekend. Thanks again!
You are turning wrenches faster than W TX windmill!
