Page 2 of 2
Re: 1969 L60
Posted: Tue Oct 26, 2021 4:19 pm
by Slackd
That is a radiator overflow someone added prior to my ownership.
Ok, I still have an issue but not sure it is overheating. To date I have drained and flushed radiator, added a 160° thermostat (there was not one in it), checked my temperature gauge with a replacement unit that came with the Patrol (same result). Here’s what happens: I start vehicle and within 3-4 minutes temp gauge shows above 212°. The thermostat housing is warm/hot, but I can put my hand on it. Bottom line, it just does not seem to get that hot. No overflow of antifreeze. So I think I have a bad temp sensing unit. Thoughts? If so, where do I get a replacement unit?
Thanks for all the help.
Dave
Re: 1969 L60
Posted: Tue Oct 26, 2021 5:24 pm
Glad to hear that you don't have an overheating issue.
I have a similar issue on mine, a 65 with a different sensor and gauge system than yours, and I been thinking on calibrating the gauge, if possible at all, rather than looking for another sensor. I have not put any thoughts on how to do it.
You can get some insight on how this gauge works at the following link:
viewtopic.php?f=21&t=2782&p=46065
There are comments on other components as well, but worth reading the part about the Temp gauge.
Re: 1969 L60
Posted: Tue Oct 26, 2021 5:33 pm
I might be the temp sending unit but likely something else. On this year Patrol there is a gauge regulator under the dash. It's screwed to the firewall under the dash to the left of the steering column, a little brass colored box with a couple of wires going to it. This might be your culprit. They can be adjusted by taking it apart. Here is a post where plateau cal describes adjusting his to make it work: viewtopic.php?f=21&t=5221&p=45526&hilit ... tor#p45526. I'd start there.
Re: 1969 L60
Posted: Fri Oct 29, 2021 9:09 am
by desertrat
RiverPatrol wrote:I might be the temp sending unit but likely something else. On this year Patrol there is a gauge regulator under the dash. It's screwed to the firewall under the dash to the left of the steering column, a little brass colored box with a couple of wires going to it. This might be your culprit. They can be adjusted by taking it apart. Here is a post where plateau cal describes adjusting his to make it work: viewtopic.php?f=21&t=5221&p=45526&hilit ... tor#p45526. I'd start there.
I was going to say the same as River and I might add that you may want to check to see if you have compatible gauges and senders. Judging by your doors being from an older Patrol than a '69 you may have other parts that have been changed out.
Re: 1969 L60
Posted: Wed Nov 03, 2021 9:07 pm
by Slackd
Thanks for the feedback. Yes, my Patrol has a slew of different parts (I think the cab has been replaced with a 64-65’ model) but all other gauges appear to work correctly. So not sure what’s not correct but believe the sensor unit is faulty.
Any leads on a replacement sensor unit?
Dave
Re: 1969 L60
Posted: Thu Nov 04, 2021 12:05 am
Re: 1969 L60
Posted: Sat Nov 06, 2021 9:12 pm
by Slackd
Temp sensor ordered. Thanks. Will update when received and installed. Dave
