Parts needed for 67 L60
Has thanked: 20 times
Been thanked: 25 times
Re: Parts needed for 67 L60
Post by Scootermixon »
Thanks Esteban…I’m looking specifically to see if anyone has the sheet metal available to match the original with the stamped/pressed ridges. There’s a lot available online for Ford and Chevrolet but the dimensions on the pressed ridges is way different and would look really obvious. Replacement pans for fj40’s and Jeep’s are pretty close so I may end up going with one of those
Scott
67 Nissan Patrol L60
Has thanked: 7711 times
zed wrote:I vote not original handle...the receiver appears original.
Keith
It is original. That's why I asked for pictures, because the soft top rear latch was different than the hard top. This is a classic example. As such, those handles are impossible to find but I think the later soft top handles will work. I don't think the hard top handle will work because as I recall it is shorter, but I may be mistaken.
7624
Been thanked: 1989 times
Good luck, I
I had one because a close friend with deep Patrol resources gifted me with the handle you seek. However, I sent it to a needy guy in Columbia......then it apparently got lost in the mail along the way. :oops: :violin:
Thanks anyway….you don’t by chance have an air cleaner?
Scott
Scott
Has thanked: 173 times
Been thanked: 306 times
Post by Peter60 »
rear door soft top handle on ebay.com.au
https://www.ebay.com.au/itm/19461633505 ... SwecxhuZVg
No relation to the seller.
