New owner here: 1967 Patrol is now in Wisconsin
Has thanked: 4 times
Been thanked: 48 times
Re: New owner here: 1967 Patrol is now in Wisconsin
Post by Sconnierider »
After a year, I'm finally able to make some progress on the Patrol. Will to figure out which direction to go on the fuel tank. This thing has more grease fittings than my 42HP tractor with attachments! Front and read diff's already dumped and refilled. Will work on the trans and transfer case tomorrow. Dropping the oil pan to take a look around. It ran pretty well before I started taking it apart, at least it fired up and idled pretty easily.
Been thanked: 1991 times
Looks like you might be a Nissan Ninja the way you are whipping those tools around!
I rehabbed five fuel tanks..just take it into shop and have them scrap as much inner wall lining out as possible...then replace all the fuel lines, rebuild the pump, and you for sure want to keep the mechanical pump, then you are finished with the easy stuff. :clap: :dance:
Rolling and Patrolling,
I called all over NE Wisconsin in an attempt to find someone that cleans out varnished tanks to no avail.. Sooo, armed with so old-timer intel from folks up here, I did it myself. Sluiced it out well with soapy water. They went and bought a 2" torch at Harbor Freight. Hooked it up to a gas grill propane bottle and proceeded (https://www.harborfreight.com/search?q= ... ng%20torch) to heat the snot out of every square inch of the tank while alternately beating (gently) on it with a large rubber mallet to dislodge the material loosened by the heat. The chips of tarnish that came out were almost 3/32" thick! Heat / cool / bang until nothing else came out. Painted the tank with a rust inhibitive product. Installed all new fuel line and clear inline filter. My local gas station up here has a non-ethanol 87 octane which I will feed it. Was not able to save the fuel sender so I purchased this setup on Amazon (https://www.amazon.com/dp/B0BQ3SD66R?re ... tails&th=1) but installed the gauge under the drivers seat adjacent to where the battery cover is as I didn't want to alter the look of the factory dash. Simply need to lift the seat the see the fuel level. Keep in mind, this is a local runner..... I don't go far. May not work for someone else.
Has thanked: 6022 times
Excellent progress and good tips on the tank cleaning.
Very interesting the fuel sender/gauge combo and your setup. Congratulations.
