Estaban, that ebay knockoff Carter carb has my Patrol humming smoothly! I have been away from this project for a bit but have now gotten back at it.
Is it possible to send me a few pics of your revised carb linkage please? I’ve got an idea but I think my angles may be a bit aggressive.
Thanks!
Shall I rebuild this carb or buy a new one? '67 Patrol
- Has thanked: 6011 times
Re: Shall I rebuild this carb or buy a new one? '67 Patrol
I will snap some pictures tomorrow afternoon.
Not the prettiest work I should say. What was done in a rush, remained permanently almost 35 years later!Sconnierider wrote:Estaban, that ebay knockoff Carter carb has my Patrol humming smoothly! I have been away from this project for a bit but have now gotten back at it.
Thanks!
At that time there were no linkage adapters of any sort, so I had a machinist turn the ball with a threaded end so I could attach it to the welded plate. Then I used the linkage of a 74 model Patrol, that is shorter than the original one of a 65 (Hitachi carburetors in both cases)
Hope you can come up with a nicer looking solution.
- Has thanked: 4 times
- Been thanked: 48 times
Much appreciated, the pics really help to confirm my ideas. And no, I doubt it will be any prettier, but like yours, it will be functional!
Best,
David
Best,
David
Esteban,
Carb is installed and choke cable hooked up. It fires off almost immediately and idles like a kitten. But I do have a stutter right when you give it a bit of throttle. I've got the air / full screw 3 turns out.
What settings are you running on yours?
David
David
If it’s running smoothly at any rpms but hesitates a bit when you give it a bit of throttle, there could be some lag at the accelerator pump (diaphragm).Sconnierider wrote:Esteban,
David
When you accelerate very slowly, the fuel coming from the pump diaphragm makes little difference.
There could be some play in the linkage that actuates the diaphragm pump.
I’m away from home at the moment. Will have to take a look at my carb to refresh myself on how to adjust it.
