Page 2 of 3
Re: Project Tub Ute
Posted: Sat May 30, 2026 2:14 am
by camo75
Motor out today and i managed to get the gearbox and bellhousing unit spilt off the enigne
The must be a club i have joined as that was no easy task.
i have removed a few engines over my time but this gearbox setup takes the cake.
Re: Project Tub Ute
Posted: Sun Jun 07, 2026 6:00 pm
by camo75
Bit of a slower weekend but managed to finish a few smaller jobs. Steering box is completed, painted and bubble wrapped for storage. Starter motor almost completed just need to purchase some glue to refit the sticker to the side.
Fan blasted and painted, fuel cleaned along with the handbrake assembly.
New task while its in my workshop is to clean and paint the clutch housing
Re: Project Tub Ute
Posted: Mon Jun 08, 2026 10:18 am
It will probably be a few pounds lighter after cleaning all the grime off.
Re: Project Tub Ute
Posted: Sun Jun 21, 2026 4:23 pm
by camo75
Finished off the bellhousing over the weekend. Tapped out the damaged threads, blasted and painted and replaced the grease nipples. Overall pretty happy with how it came out.
Used GM Blue as it seems like the closest i could find to the Nissan color
Ready for storage
There are some brackets on the chassis i was keen to understand if anyone knows what they were for
Re: Project Tub Ute
Posted: Mon Jun 22, 2026 11:34 am
Nice work on the trans. The brackets are for the exhaust.
Re: Project Tub Ute
Posted: Thu Jul 16, 2026 3:57 pm
by camo75
Update on project progress.
sadly the previous owner had welded a large amount of steel to the chassis which i found difficult to remove. Under the steel the chassis wasn't in the best condition so i decided to use a donor cars good bits to repair mine.
I cut out the damaged sections and replaced them and i am quite happy with the results.
I know some might comment around chassis mods but short of adding a lot of extra steel and making it look worse i couldn't find a solution to repair that i thought would present well. i may look at welding on some external plate to reinforce the welds but am yet to decide on this
one step closer to sending the chassis away to be blasted
Re: Project Tub Ute
Posted: Thu Jul 16, 2026 5:17 pm
by zed
Would you have a photo of the frame mounting nuts for the tow hook?
Thanks, Keith
Re: Project Tub Ute
Posted: Fri Jul 17, 2026 11:54 am
That was a whole lot of steel added!
Looks like you did a great job.
Re: Project Tub Ute
Posted: Mon Jul 27, 2026 3:21 pm
by camo75
zed wrote: ↑Thu Jul 16, 2026 5:17 pm
Thanks, Keith
Hopefully this helps
Re: Project Tub Ute
Posted: Sat Aug 15, 2026 5:18 am
by RED DOG
looks like a great project, i wouldn't worry about plating over the welds you did, it looks like a great job,
