Patrol refurb + minor upgrades
Has thanked: 7700 times
Been thanked: 2478 times
Re: Patrol refurb + minor upgrades
Cool! The texture looks very similar to the original fiberboard and it will certainly hold up a lot better. :D
Has thanked: 5 times
Been thanked: 24 times
Post by BR_Patrol »
I FINALLY found the correct speedometer cable for my '69 (female at transfer, male at speedo) which is different from my Dad's '68.
Wanted to share here since I am more or less using this threads to keep my build notes together when I think it's worth sharing, but I also added it to a Speedometer cable thread already started.
See pictures for part number and my different speedo back end.
Post by BR_Patrol »
Another part option found for radiator hoses. I will look to see if there is a radiator hose compatibility thread but these two Gates hoses from O'Reilly's match the profile nearly perfect once you trim the excess. Not sure what vehicle the original length was intended for, but cut out the portion that has the profile you need. One hose was about $25 and the other $33 I believe.
Part numbers are in the picture but also:
Top hose - Gates 22301
Bottom hose - Gates 20584
