Moore_rb's 1965 Hardtop Patrol...L60-3-00617
Has thanked: 233 times
Been thanked: 165 times
Re: Moore_rb's White 65 Hardtop...
Post by pdub »
Wow so my multi colored set up is stock. I thought someone swapped the transfer case out at some time. Now I have to decide on original or not. I'm thinking all blue would look much better. Hmmmm
1967 Patrol
2017 Toyota Tacoma
1968 Camaro
1968 Disneyland Autopia Car
The Machine Shop called this past Thursday...:
"Just wanted to let you know we're running a little behind, but we'll get to your engine block here in a couple days..."
Greeeeaaaaat.... :roll:
WOOT !
Engine block is back from the machine shop - cylinders are bored .050 (1.25mm) to match the donor pistons, and the head deck was double- checked for flatness...
So, with confirmation that this engine is totally rebuildable, I went ahead and ordered my main bearings, rod bearings, and piston rings today.
Things are moving slowly, but at least they haven't ground to a complete halt 8-)
Has thanked: 84 times
Been thanked: 327 times
Post by miller »
:dance: :clap: :dance: :clap: Finally!
Post by pdub »
Block looks great!!
1967 Patrol
2017 Toyota Tacoma
1968 Camaro
Has thanked: 7743 times
Been thanked: 2482 times
Sweet!
{Sigh...}
Where, oh where, are my main bearings....?????
Still waiting. Still.......
.......Waiting.
:confusion-waiting:
Besides- It's still hot. Hot Hotter Hottest.
Hot
Post by pdub »
Ah. 77 degrees here just wrenching in the garage now. :D
1967 Patrol
2017 Toyota Tacoma
1968 Camaro
Yay - My main bearings arrived today... :dance:
I am very close to doing me some engine rebuilding.... 8-)
My piston rings that I ordered are wrong... :cry:
I told Hastings I needed .050" over (50 thousandths of an inch, or 1.25mm over bore), and they sent me .50mm over, which is only .020" over, so they are too small.
And to compound the issue, Hastings doesn't even offer .050/1.25mm oversize rings in the Nissan PPU/P40 set - They offer .020, .030, .040, and then they jump to .060.... :doh:
But, they are willing to take the wrong ones back and do a return order for me, so I guess I'm going to get the .060 rings, and file the compression rings down to achieve the correct gap (the hot-rod gearhead in me is all over this idea 8-) ).
For the oil scrapers, I will file the framing rings the same way, and then will decide whether to re-size the flex ring, or re-use the flex rings that are already on the pistons... :think:
