Update.............went to work on the Patrol yesterday. Got the outside of the trunnions (knuckles) cleaned up on the outside, and got them painted. Also cleaned up some on the inside, at least removing a lot of the old grease. Grease wasn't necessarily bad, but sure was a lot of it.
I had intended to clean up & paint more of the front axle, but after looking at it some, decided to wait. Spring 2023 project will be to replace the shocks and sway bar bushings, so painting will be easier with that stuff out of the way. Besides, it was kinda cold yesterday morning here in NC, and breezy. Here are a couple of pics of the finished job, with the trunnions taped back up:
One thing I noticed is that only the top knuckle bearing flange cap has a grease fitting. I guess the grease is just supposed to flow via gravity to the lower knuckle bearing. If the bottom flange cap ever has to come off, I'll probably drill and tap it for a grease fitting.
Earlier this week, got finished getting the stub shaft, universal parts, and spindle cleaned up. Will have to pack the bearing inside the spindle, but will do that when the wheel bearings are packed. For now, they are in big freezer backs to keep them clean.
Also got the backing plates all assembled -- wheel cylinders (even went anal and made the gaskets that go between the backing plate and wheel cylinders
), brake lines and junction blocks, and shoes. The tie wraps are temporary of course, to hold the shoes from moving around; once the backing plates are on the car, the springs can be installed. I'm really glad I pulled the backing plates/spindles/etc off. Basides being able to do a much better job of cleaning and painting, the new brake lines would have been a bear to fine tune with the backing plates installed on the axle. The brake lines are the somewhat new Copper-Nickle (NiCopp) material.
I'm so glad that the Australian wheel cylinders are available, but the anal engineer in me doesn't like the fact that the slots in pistons are a lot wider than the thickness of the brake shoe web. On the rears, using the original pistons in the new cylinders took care of this, but no good way to fix this on the fronts short of welding up the web on that end of the shoe and machining it down. I ain't going that far.........guess I just live with it.
Next jobs are to get the drums cleaned up and painted, then get the wheel bearing packed and the seals installed on the hubs. This will put me ready to start putting all this back together this coming Friday.
Need some feedback on a technical question: there were no gaskets between the trunnion (knuckle), the backing plate, and the spindle. Looking at the parts manual, there are none shown. With the inside of the trunnion (knuckle) loaded with grease, I would have expected some really thin gaskets. Thinking that maybe a light coat of Permatex Aviation Form-a-Gasket (the liquid type with the brush on the cap) would be good to put on these parts before bolting it all together. Opinions and/or advice??
