Page 13 of 20
Re: Paul's 1967 Restoration
Posted: Sat Oct 08, 2016 12:27 pm
I'll bet your neighbors love you.
Posted: Tue Jan 10, 2017 9:02 pm
by pdub
Well I'd beed drading this repair for awhile. The lower left side door hinge attaching plate had come loose in the door frame. Upon examining all access possibilities I chose to cut through the outside skin. I then come to find out there is a internal box wall as well. After cutting into that I finally found the plate and attaching piece. I then drilled 2 holes in the door frame to weld through to the attaching strap. It worked out great. The plate is back in place and moves to adjust the door hinge. Just have to finish welding the internal wall and make a patch for the outer skin. Problem solved
Posted: Wed Jan 11, 2017 12:14 pm
That was brave. I don't know of anyone else who has tackled that.
Posted: Sat Mar 18, 2017 7:58 pm
by pdub
Anyone have a set or passenger side (right) step brackets you can take a picture of. Trying to figure out if these are bent or if the curve is normal.
Posted: Mon Mar 20, 2017 11:58 am
by moore_rb
The curve is normal on the forward bracket... They look to be in great shape
Posted: Sat Apr 15, 2017 9:17 pm
by pdub
Getting way ahead of myself. My friend was going to the chromer's so I tossed a few things in with his order. Can't wait to put these on in a feeeeew months.
Posted: Sun Apr 16, 2017 11:22 am
Ooooo...shiny.
Posted: Wed May 10, 2017 10:56 am
by Redpatrol7760
Man, great work! Makes the job look not so daunting. I'll be starting the year down of my '67 in two weeks!
Posted: Wed Jun 07, 2017 10:05 pm
by pdub
I was amazed today. I saw my first Patrol on the road since I was 13 yrs. old. Not counting car shows or friends. Note the FJ tail lights. Not a bad look.
Posted: Thu Jun 08, 2017 9:57 am
That's my old '69!
My buddy that lives in Mission Viejo that I told you about. He just finally brought it home from the river. Leave a note on it for him.
I used the FJ tail lights because they were readily available, as were the FJ mirrors. Those were very vulnerable parts when doing some extreme off roading and I didn't want to sacrifice the originals. Trust me, I left some FJ trail debris a few times.
