69 rat house
Has thanked: 81 times
Been thanked: 173 times
Re: 69 rat house
Post by nizmut »
swaybar bushings http://www.energysuspensionparts.com/9.5124
endlinks http://www.energysuspensionparts.com/9.8163
The drag link end covers and tie rod end covers are off the compatible parts list
Robin
Has thanked: 351 times
Been thanked: 301 times
Re: 69 rat house
Post by mdawg4x4 »
nizmut wrote:swaybar bushings http://www.energysuspensionparts.com/9.5124
I'll be curious to see how these work out. And your brake line skills are mad! I don't want anybody looking at mine.
Re: 69 rat house
Post by nizmut »
My thumbs hurt for 2 days after the brake lines :lol:
Robin
Re: 69 rat house
Post by nizmut »
Well looks like we hit a snafu. Pulled the rear axle to install the rear springs yesterday. After pulling the axles to pack the bearings I drained the diff to change the gear lube. Had some large bits of shim stock on the magnet along with the normal paste. Also what appears to be flakes of chrome, probably the facing on the gears or bearings. So I decided to move it in the shop and open it up.
So I went into the shop and set 2 pipe stands up, walked out and picked it up, clunk. What the hell? Every step, clunk. It is about 50' from the stands outside to the stands inside so lots of clunks.
Pulled the cover and found .050 inches (1.25mm) of end play in the carrier, could be more, the pinion could be stopping it. Lets just say there is enough play I can watch the bearings ride up and down the tapers going side to side.
So not to confident in this ring and pinion.
So if anybody has a ring and pinion, or diff laying around let me know.
Also Esteban do you remember what bearings you used. And the shop manual says the front and rear are the same parts. Is that true for the R&P also?
Robin
Has thanked: 6013 times
Re: 69 rat house
Sorry to hear about the problems with your rear diff.
nizmut wrote: Also Esteban do you remember what bearings you used. And the shop manual says the front and rear are the same parts. Is that true for the R&P also?
If your front differential is in good condition, that should be your first option. All the parts are exactly the same. In addition, the normal wear happens in the opposite side of the pinion teeth faces (like if the rear differential was constantly driven in reverse!) so you can have a fresh start once swapped front to back. If the bearings at the front differential are in good condition, what I've done in the past is swap all the components entirely from front to back, without worrying about the setup.
In October 2013 I repaired my rear differential. I think I never wrote all the details about it, so I need to do that. Since the repair, I've driven 4,000 miles, so I called it good. By the way, I couldn't do the swap of front to rear, since that was already done years ago.
If you plan on repairing it, please do a contact pattern of the gears before dismantling. You will want to replicate that pattern once the new parts are installed.
The following are the bearings involved:
Pinion Bearings: 30207, 32208, one each.
Carrier Bearings: 32209JX, two needed (these bearings are basically unobtanium) I used 32209 bearings instead. The problem is that the bearing cup for the JX one is unique to the Patrol. It's about 3mm taller than a standard cup. I improvised some shims for this.
Here is a thread from ToadsPatrol. He used the original bearings that he had purchase years ago.
http://www.60patrol.com/forum/viewtopic ... 31&p=38857
And here's the one with some of my initial concerns about the carrier bearings and how to solve it:
http://www.60patrol.com/forum/viewtopic ... 26&p=15710
I mention there Ratech Manufacturing, where I purchase the shims. I will try to come with the list of shims and combinations of them.
Re: 69 rat house
Post by nizmut »
Cool, I have a spare front Haven't opened it up yet to see what it looks like.
Robin
Re: 69 rat house
Post by nizmut »
Robin
Re: 69 rat house
nizmut wrote:https://mypartsgarage.com/catalog-2/itemdetail/national-seal-bearing/32209-a ?
That looks like the regular bearing, not the one with the extra width cup. Similar to the one I ended up installing.
Re: 69 rat house
Post by nizmut »
So this showed up today.
https://www.amazon.com/gp/product/B0101 ... UTF8&psc=1
Looks just like the one I pulled out of the clutch master. I will let you know when I get it in.
Robin
Re: 69 rat house
Post by nizmut »
Still stuck at the rear axle, took a little work to get this out of the spare front.
Ring gear looks good, set up is good, now to look inside the carrier and see if I can swap parts around and make one out of 2.
Robin
