As requested, here are some progress pictures....
First I finished bending and welded up the "extension" piece that will go in the front of the tank. Then leak tested it. then fixed some pinholes....leak test, fix holes, repeat....
First baffle welded in:
Test fit! My measurements were pretty good...its a very snug fit! Honestly I would have liked to make it about 1" smaller on horizontal dimensions, but this will do.
My level sensor hole came out perfect to where I made the new pass through in the Patrol's floor. Also marked my "clear" areas for adding the barbs
barbs added for Return, Vent, and Feed. notice I changed where I put my feed port from my CAD model. I decided I wanted everything accessible via the removable floor plates in the Patrol.
One view of the feed line before closing up the tank:
Another view after tank has been tacked back together:
This is how I tied the top of the baffles into the top piece of the tank....cut a slit where the baffles would be and welded from the outside of the tank.
This is where Im at right now. All welded up and started cleaning up the welds. I ran out of grinding discs at this point...more work later today!
