Page 3 of 4
P40 distributor fit L60?
Posted: Wed Oct 24, 2007 12:21 am
by npca-lmtshootingstar
You could go to Petronix with that Part Number
http://www.pertronix.com/home.htm
Posted: Mon Oct 29, 2007 4:00 pm
by npca-yellowpig0
i looked this part noumber up ...could not find..
Posted: Mon Oct 29, 2007 8:16 pm
by npca-67l60
need to go thru a forklift company it wont be in general circulation the part number is correct and is not a pertronix standard number so looking in the pertronix add's won't help since there is no listing for a nissan patrol
Posted: Mon Oct 29, 2007 8:29 pm
by npca-67l60
This message has been deleted by the author.
Posted: Mon Oct 29, 2007 8:47 pm
by npca-67l60
Posted: Mon Oct 29, 2007 8:50 pm
by npca-67l60
pertronix catalog for 2007 industrial section page 29 komatsu p40 part number 1761 also note same number as the early hitachi 280 z 1761 2 different ways to order it same part in the box good luck
Posted: Tue Oct 30, 2007 1:02 am
npca-67l60 you are an amazing wealth of knowledge!!!
Posted: Sat Dec 29, 2007 9:09 pm
by npca-patrolman200191
take out your number one spark plug and make sure the piston it all the way up when the the points are making contact using a soft pen is the safest way to know its tdc. the rotor must be turning counter clockwise, if its not its firing backwards causing it to fire in reverse making it back fire
Posted: Fri Apr 11, 2008 3:11 pm
by npca-yellowpig0
will this new distributor fit a 69 patrol...I need one mine will jump out sometimes i want to up grade....Sparky.....
Posted: Fri Apr 11, 2008 3:13 pm
by npca-yellowpig0
Where can i get the ignightor...will it fit in my dist..69 patrol...
