Has thanked: 6017 times
Been thanked: 1601 times
Regarding the studs, this is from another thread about lug size:
zed wrote:So far I have determined:
1/2”x20 fine thread
5/8” length
13/16” hex
I do not have an original lug wrench, so can someone please confirm the 13/16” hex dimension?
Thanks,
Keith
Lug nut wrench size is correct as well.
.....and that is a 13/16
Been thanked: 46 times
Post by IrishPatrol »
I think I may have one on for my spare.... i dont plan to run those wheels. How do we know for sure??? Got a pic and dimensions?
Ok, whats the best way to get these old grease fittings to take greasing??? some will some wont. I know it needs it.
grease zerks are cheap.. they sell boxes of them at the local auto parts store in all configurations (straight, 45 degree, 90 degree)
just unscrew the "stuck" ones, and screw in the new one, and grease away...
Nice! Thanks.
Can some one tell me if there is a seperate fill plug or hole for each the transmision and transfer case? One fill and drain for each or one for both? Looking at the service guide is a little vague. Also what is the Hole with the pull in the floor board where the shifters are? Is the a dip stick for trans oil? Forgive my ignorance here.
Has thanked: 7703 times
They both have separate drain and fill plugs. The plug with the pull handle is the fill for the transmission, and it acts as a dipstick too. It screws in to the trans.
I knew it, How do you know how much to put is befor your over full? Like on the Diferential and trans the fill hole is at the full level..... Iguess drain and put in 2. liters?
The transfer you fill until it starts coming out the hole. The transmission you fill until it reads full on the dipstick. It is going to take over a gallon of oil for both. Here is a chart that lists capacities and other good stuff: http://www.60patrol.com/forum/viewtopic.php?f=32&t=1933
