Page 3 of 3
Re: 78' SWB upgrade ideas/help
Posted: Mon Feb 19, 2018 5:24 pm
by Johnny Roadkill
Hi Bluey,
try this link for the fitting instructions for the Mark's box - should let you know what you're up for.
http://60patrol.com/forum/viewtopic.php ... 137#p39137
I have heard there are 2 sets of ratios, but I don't know of a way to check them externally except for rotation, sorry.
The biggest issue I think you're likely to face is the tailshaft lengths in a SWB. Notching the crossmember wasn't required in my MWB apparently - it's still stock. In the 3 Mark's boxes I have had one was significantly looser in the linkages than the others, and also that same one had water in the transmission oil - check that if the one you're looking at has been sitting outside for a while ( the water will sit at the bottom so a quick check at the drain plug will suffice ).
cheers,
D
Posted: Tue Feb 20, 2018 6:06 am
by Bluey
Goodo, i shall check that link out now, thanks.
Fairly sure i read somewhere that I shouldn't have to notch out the cross member, but then again maybe it wasn't talking about a SWB? lol
So what other parts were there other then the box itself? it was a kit right?
Posted: Tue Feb 20, 2018 6:25 am
by Bluey
OK scrap that last question, There is a list of parts in that Link that Johnny provided.. Most of that should be attached anyway... hopefully? :pray:
