Page 3 of 3
Re: Rough Running Patrol
Posted: Sun Mar 20, 2022 3:05 pm
by plateaucal
Another old school diagnostic test uses a vacuum gauge. For instance: low vacuum may mean worn rings (will show on compression test as well), vacuum leak, wrong valve timing (slipped timing chain), retarded ignition timing, Oscillating vacuum may mean leaky valve or weak springs. Vacuum that drops steadily may be a plugged exhaust.
Just a thought.
Posted: Sun Mar 20, 2022 7:18 pm
by Slackd
Thanks to all for their input. Much appreciated.
Posted: Sat Apr 02, 2022 11:40 am
by rrbipu
Any luck? I can't get mine to stop backfiring un acceleration. I'm working down the list of items. Were did you get your distributor cap and button? I can't find them.
Posted: Mon Apr 04, 2022 9:12 pm
by Slackd
Installed new condenser and points. Seems a little better but still rough at low RPM, runs strong and smooth at higher RPM (>1200). Definitely runs smoother with a little mechanical choke applied.
Posted: Tue Apr 05, 2022 10:05 am
Slackd wrote:Installed new condenser and points. Seems a little better but still rough at low RPM, runs strong and smooth at higher RPM (>1200). Definitely runs smoother with a little mechanical choke applied.
Your timing is probably a bit retarded. Might be at 0 degrees BTDC. Should be at 10 degrees BTDC.
Posted: Tue Apr 05, 2022 11:35 am
by Slackd
Thanks Esteban!
