Page 21 of 22
Re: 1969 Patrol, Take 2: Action!
Posted: Thu Aug 13, 2020 10:06 am
by yitzac1990
actually i have a question...i wanna leak test the tank, but dont want to use water, because then obviously the metal will start rusting already. Gasoline is obviously too expensive to waste on a leak test. Does anyone have any suggestions? I might try to pressurize the tank with air instead, but then id have to make blocking plates for the big holes and such. hmm....
Posted: Thu Aug 13, 2020 10:52 am
by moore_rb
You could etch and seal the inside, which would allow you to leak-test with water, AND would offer the additional benefit of longer overall lifespan for the tank...
https://www.eastwood.com/ew-gas-tank-se ... -cars.html
Posted: Thu Aug 13, 2020 11:03 am
Posted: Thu Aug 13, 2020 11:34 am
by yitzac1990
out of stock
grrrr
Posted: Thu Aug 13, 2020 12:57 pm
by jwgreen
Posted: Thu Aug 13, 2020 3:21 pm
by plateaucal
https://www.grainger.com/product/1VNF4? ... 2900016105!
Get some plumbers plugs for the big holes as shown in the link above. Pressurize with air...careful though. Use a hand pump to about 2 psi I would guess. . Install a low pressure gauge maybe with 0.1 psi increments.Then soap and water looking for bubbles. Let sit overnight to see if pressure drops. Keep in mind that temperature fluctuation may change pressure reading.
Posted: Tue Aug 18, 2020 7:09 am
by yitzac1990
well the tank is almost done. I have one small leak at the drain plug I put in. I want to "do it right" and empty the tank, take the tank back out, and re-weld around the drain plug nut. Until then, here are some pictures:
my pressure testing rig worked real well!
finished
top view from the Patrol...everything lined up great
bottom rear...
bottom front...
Posted: Tue Aug 18, 2020 8:28 am
Finished work looks tops! Congratulations.
Did you made the fuel barbs?
Posted: Wed Aug 19, 2020 11:13 am
by yitzac1990
the barb fittings I found on ebay, they are 3/8", and apparently made for soda dispenser machines! whatever works, right?
Posted: Wed Aug 19, 2020 3:32 pm
Great find! Thanks
