Thanks, sleepyzzzsleepyzzz wrote:you have done a really good job making that rig look new. very nice work
Looking for Map Light (Found no longer looking!)
- Has thanked: 38 times
- Been thanked: 30 times
Re: Looking for Map Light (Found no longer looking!)
- Has thanked: 97 times
- Been thanked: 568 times
Man you do some nice resto work on those parts!!! I may have to start sending all my stuff to you for resto!! Keep up the great work!!!
- Has thanked: 203 times
- Been thanked: 678 times
FYI,
The lens diffuser is similar (but smaller in diameter) than the one on the Datsun Z car. The Datsun Z car lens will fit
will fit the Patrol inspection lamp housing, but a bit a packing material may be required to keep the lens in place.
Patrol diffuser on left
Datsun Z car diffuser on right
Keith
Keith
Thanks, Justin.jwgreen wrote:Man you do some nice resto work on those parts!!! I may have to start sending all my stuff to you for resto!! Keep up the great work!!!
I like the pretty part of restoring stuff. Its the mechanical stuff I have the
problem with! Lol
Thanks again
Kris
Hi Keithzed wrote:FYI,
Keith
thanks for the info. why do you think they would create 2 different parts if they are almost the same?
Seems to me they'd save a ton by using the same parts. ???
Kris
The diffuser I have in my 1969 Patrol is made of glass, the Datsun Z diffuser is plastic. I will have to post a photo of the Datsun Z housing, the mounting bracket is different. Also, the switch on Patrol unit has a metal toggle and base while the Datsun Z is plastic.
The Patrol seems to be based on the standard "inch" system while the Datsun Z is based on the metric metric system. Perhaps this accounts for some of the difference in specifications.
Keith
Keith
- Has thanked: 351 times
- Been thanked: 301 times
My experience is different groups designing different products and no communication between the two groups.antiquecyles wrote:Hi Keithzed wrote:FYI,
Keith
Kris
The larger one was designed 1st and was a little too big for the desired look of the 2nd application.
Then there are the styling people that demand the slight difference will make sales that much better.
Another theory;
Just to pi** off the parts manufacturers.
Keith
Keith
Ha!zed wrote:Another theory;
Keith
I guess they (designers) would be the only ones who know
can you tell me if I am missing a part?
I would think there would be some type of bezel/trim piece covering the base of the lens. I
can see the tabs that hold the glass and the rubber underneath. I would think that would have a cleaner design, especially being on the dash?
Thanks
KRIS
There is a thin plastic/translucent film that seats to the base of the housing - acts as an heat insulator (sandwiched between the black washer and the housing)
There is a thin black rubber washer that adds pressure to beep the lens in place (sandwiched between the plastic/translucent film and the lens).
Keith
Keith
