Page 4 of 4
Re: 1969 Patrol Transmission Swap is Happening!
Posted: Thu Dec 10, 2020 3:33 pm
by faux40
That cross member looks great! That is the cutest little driveshaft! So happy it works!
Posted: Thu Dec 10, 2020 6:39 pm
by r1lark
Wow, beautiful work! :clap:
And really good video too. I need to go back and watch all your other videos.
Posted: Wed Jan 06, 2021 12:56 am
by seth1001
Here's a fun one. Stayed tuned for final updates. This project looks like it's finally drawing to a close.
https://youtu.be/leGpcbLgzXc
Posted: Wed Jan 06, 2021 9:11 am
by r1lark
Great! :greetings-clappingorange:
So the transmission in the Patrol now, was that a used one? I can't remember from previous posts.
Posted: Mon Jan 11, 2021 11:52 am
by yitzac1990
Congrats! What is the ratio of the 4th and 5th gears of that NV4500?
It looks like the transfer case is resting on that skid plate, i would look into that and trim the plate a bit, if so...
I have had an overdrive unit for my transfer case sitting on my workbench for months, just havent had time to get to it. too many other projects going on. But it should give me a "5th gear" of 0.70:1. I wonder how that would compare to your real 5th gear, and if I could acheive 80 mph without revving too high.
Posted: Wed Jan 20, 2021 10:16 pm
by seth1001
r1lark wrote:Great! :greetings-clappingorange:
The one in the video is a "brand new" transmission from AllState Gear. I don't recommend them. Since then I've put in a rebuilt replacement from High Impact Transmission and Gear. It's much better and I expect to post a new video featuring that transmission in the next few weeks. I'm in the process of cleaning up other stuff and rigging up some new sheet metal to plug the holes in the transmission tunnel.
Posted: Wed Jan 20, 2021 10:25 pm
by seth1001
yitzac1990 wrote:Congrats! What is the ratio of the 4th and 5th gears of that NV4500?
The 4th gear is a 1:1 and the 5th is a 0.73:1. Depending on your tire size you may be able to beat mine in top speed, but if you have the original engine in there then you might not have the power to wind it up that high. Best of luck to you either way though. Make sure to post about it on the forum if you get it in there.
Posted: Wed Jan 27, 2021 12:28 pm
by yitzac1990
seth1001 wrote:The 4th gear is a 1:1 and the 5th is a 0.73:1. Depending on your tire size you may be able to beat mine in top speed, but if you have the original engine in there then you might not have the power to wind it up that high. Best of luck to you either way though. Make sure to post about it on the forum if you get it in there.
Thanks! I am LS powered, i don't think ill have a problem with power haha
