Page 35 of 58
Posted: Thu May 26, 2016 9:35 pm
by moore_rb
Hey that's good news Esteban.... saves me from having to figure out how to box up this monstrosity...
Posted: Sat Jun 11, 2016 5:17 pm
by nizmut
So I have rot in both doors where The braces are. Does any one know what gauge the door metal is? Also could use a front hood badge, and a windshield vent for a 69.
Posted: Mon Oct 24, 2016 10:56 am
by Kdiv_n_tx
Can someone take a picture of how the upper release lever attaches to the spare tire carrier? My spare tire carrier is mounted in back, as appropriate for a 1970 MWB, but the upper lever and spring came in a parts box. I have the loop on the backend of the Patrol that the lever engages into and the lower catch/post/release all work perfectly. I plan to mount a spare onto the carrier and just know the weight of the wheel and tire will overwhelm the bottom unit only.
TIA,
Kirk
Posted: Mon Oct 24, 2016 3:30 pm
by rjiggy
Kdiv_n_tx wrote:Can someone take a picture of how the upper release lever attaches to the spare tire carrier? My spare tire carrier is mounted in back, as appropriate for a 1970 MWB, but the upper lever and spring came in a parts box. I have the loop on the backend of the Patrol that the lever engages into and the lower catch/post/release all work perfectly. I plan to mount a spare onto the carrier and just know the weight of the wheel and tire will overwhelm the bottom unit only.
TIA,
Kirk
This might help.
http://www.60patrol.com/forum/gallery/i ... play=popup
Rick
Posted: Mon Oct 24, 2016 7:48 pm
by rjiggy
Kirk,
Here's a couple of photos from the boneyard.
Rick
Posted: Thu Oct 27, 2016 6:35 am
by Peter60
Gearbox Questions.
I have a spare gearbox/transfer and it has two electronic sensors on it which my current gear box doesn't have.
What is the one on the top? I assume the one on the side is to show if the transfer case is in 4WD.
Also is there a filler point for the gearbox? I ended up adding oil via the dip stick.
Posted: Thu Oct 27, 2016 6:45 am
by Peter60
Speedo Oil Seal
I have the following small oil seal that goes in the gearbox where the speedo cable goes in.
Which way does it go? The seal has a small metal ring/spring in one side.
It seems to be no matter which way I put it in the speedo still leaks oil.
If I didn't use the speedo cable at all, what could I plug the outlet with so it stops leaking?
Posted: Thu Oct 27, 2016 8:24 am
Peter60 wrote:Gearbox Questions.
The one on top is the reverse light sensor. You are correct about the one on the side. And, the dip stick is the correct fill point.
Posted: Sat Nov 12, 2016 7:49 pm
by nizmut
Need something to replace the drive line dust seal cork. Was thinking graphite packing. Any one come up with something that works?
Posted: Wed Nov 16, 2016 2:13 pm
by jwgreen
What transmission/transfer case oil are folks using these days?
