No worries. I pulled it all apart and got all the bearings for it. I just have to drill out and tap the drain plug hole in the bottom and then put it all back together, if I can remember how seeing as its been awhile since I got it all apart.moore_rb wrote:jwgreen wrote:Have you done anything to it?? Do you have any part numbers, not the ones out of the parts book because those lead no where, to any of the bearings or the oil and dust seal??moore_rb wrote:yup, that looks like the same factory PTO I have on my green 66.. I also have a Koenig winch on mine as well.
Wow Sorry Justin - I totally missed this inquiry...
But, no, I have not done anything to my PTO, and my attempts to find any relevant technical information about it have also turned up fruitless...
Texas 1969 KL60
- Has thanked: 97 times
- Been thanked: 568 times
Re: Texas 1969 KL60
Re: Texas 1969 KL60
Its been a while so I thought I'd give a quick update on my project. Over the last couple months I have rebuilt the transmission and transfer case, installed the bell housing, flywheel and clutch assy, painted the frame, reconditioned the starter and got my new header from the land down under. I am waiting to pick up the frame from the paint shop then I will get to putting a rolling chassis together. I will add some photos in the next few days. I do have a question. Is there a replacement Clutch Slave Cylinder out there in the US?? I found on in AUS but it cost as much to ship it as the thing costs. My slave is pretty badly pitted so I would rather replace it than have it repaired. Also the service manual talks about a Warning Switch located on the Transfer case, does anyone have a part number or know where to get one?
Re: Texas 1969 KL60
Mufflers to the Max is where I got mine from. They should be able to hook you up no pblm. Part # HU071STdarren wrote:gday mate just where you bought your header from in oz have had trouble finding a supplier
Re: Texas 1969 KL60
I have a new, still in the box Protex clutch slave cylinder (part # JB4048) that Miller sent me along with my 5 speed, but both of my Patrols are manual clutch linkage, so I have no use for it.jwgreen wrote: Is there a replacement Clutch Slave Cylinder out there in the US?? I found on in AUS but it cost as much to ship it as the thing costs. My slave is pretty badly pitted so I would rather replace it than have it repaired. ?
PM me best price you can find for it online(minus shipping) and I'll get the USPS flat rate shipping cost from Az to Tx.
Re: Texas 1969 KL60
Awesome!! PM sent!moore_rb wrote:I have a new, still in the box Protex clutch slave cylinder (part # JB4048) that Miller sent me along with my 5 speed, but both of my Patrols are manual clutch linkage, so I have no use for it.jwgreen wrote: Is there a replacement Clutch Slave Cylinder out there in the US?? I found on in AUS but it cost as much to ship it as the thing costs. My slave is pretty badly pitted so I would rather replace it than have it repaired. ?
- Has thanked: 6011 times
Re: Texas 1969 KL60
According to the Parts Manual, the Warning Switch is 32005-H5000 I think that around 1975 they started coming with the warning lamp in the dash.jwgreen wrote:.., Also the service manual talks about a Warning Switch located on the Transfer case, does anyone have a part number or know where to get one?
Doing a search, that part has been updated to 32005-K121A at http://www.everythingnissan.com/Nissan- ... h5000-.htm
Disclaimer: I have never used this place. And some others that claim to have the parts, when it comes to the Patrol, after a couple of days they send an email saying that they're sorry but the parts are no longer available.
I found this interesting information regarding that switch:
http://datsun1200.com/modules/mediawiki ... amp_Switch
32005-K121A Rev Lamp B110 $33.70 USD
Used by all Datsun 1200
Most 60-series 4-speeds B210/B310
FSW560L 60-series 'dogleg' 5-speed B310
Some FSW560A 60-series 5-speed B310
Also used in early 4TH-gear switch (USA B110)
Aftermarket
* BWD S9254 (w/spade terminals)
* ACDelco E2202
* ACDelco E2228D
* Master Pro 2-8943 (w/bullet terminals)
* Original Engine Management 8943
* Standard Motor Product/Intermotor LS325
* AirTex/Wells 1S5440
Back Up Lamp Switch
Re: Texas 1969 KL60
WOWEsteban wrote:According to the Parts Manual, the Warning Switch is 32005-H5000 I think that around 1975 they started coming with the warning lamp in the dash.jwgreen wrote:.., Also the service manual talks about a Warning Switch located on the Transfer case, does anyone have a part number or know where to get one?
Aftermarket
* ACDelco E2202
* ACDelco E2228D
Back Up Lamp Switch
Re: Texas 1969 KL60
Can someone tell me if these are a direct replacement for ours?? Says if should fit a NISSAN PATROL SAFARI Y60 1987-1997.
http://www.amazon.com/Febest-Nissan-Uni ... B00C6MU140
Re: Texas 1969 KL60
jwgreen wrote: I will add some photos in the next few days.
