1964 Nissan Patrol soft top frame off restoration
Has thanked: 181 times
Been thanked: 174 times
Re: 1964 Nissan Patrol soft top frame off restoration
Post by RMP&O »
Before you go and buy one of the expensive fuel caps that are available out there, consider this. On the left is the cover from one of these, on the right is an original cover. Notice the left one the door is attached via a punched pin, the original uses a screw. The one on the left fell apart when I took it out of the box, fixing it is near impossible, it was not cheap. I think I am going to have to have the original chromed instead, non-glare chrome.
Cheers
Has thanked: 87 times
Been thanked: 207 times
Post by rrodriguezsal »
Hi Ian. I can not identify this cap. Could you please post other picture showing the other side. Thanks
RMP&O wrote:Before you go and buy one of the expensive fuel caps that are available out there, consider this. On the left is the cover from one of these, on the right is an original cover. Notice the left one the door is attached via a punched pin, the original uses a screw. The one on the left fell apart when I took it out of the box, fixing it is near impossible, it was not cheap. I think I am going to have to have the original chromed instead, non-glare chrome.
Cheers
Post by RMP&O »
Sure, you bet!
Cheers
zed
Has thanked: 203 times
Been thanked: 678 times
Post by zed »
RMP&O wrote: And yes, Yazaki is the company that manufactured these wiring harnesses for Nissan.
Has anyone found a source for original Yazaki terminals?
Thanks,
Keith
