Starter
- Has thanked: 23 times
- Been thanked: 223 times
Re: Starter
Hey, I haven't had the issue go away actually. Doesn't happen every time, maybe one out of seven or eight starts. I haven't diagnosed yet if my flywheel has teeth that are worn or if it's the starter itself. Will take the cover plate off my clutch housing next week and take a look for you if you're interested. Haven't driven that much this winter so it hasn't been on my mind. if it's persistent I might try to come up with another starter solution like rebuilding my original..
- Has thanked: 17 times
- Been thanked: 115 times
Re: Starter
No need for all that. I appreciate the info as is!curlrider11 wrote:Hey, I haven't had the issue go away actually. Doesn't happen every time, maybe one out of seven or eight starts. I haven't diagnosed yet if my flywheel has teeth that are worn or if it's the starter itself. Will take the cover plate off my clutch housing next week and take a look for you if you're interested. Haven't driven that much this winter so it hasn't been on my mind. if it's persistent I might try to come up with another starter solution like rebuilding my original..
