1971 Nissan Patrol from Mexico
Has thanked: 7689 times
Re: 1971 Nissan Patrol from Mexico
Congratulations!
Removing the steering wheel is the easiest.
Has thanked: 38 times
Been thanked: 47 times
Post by KyleAnschuetz »
It has been a while since I have posted. I bought a house and then had to setup a garage.
With warm weather and an outfited garage I have started the process of getting my patrol together. Currently the Patrol sits on a painted frame, new suspension and a rebuilt engine with a new clutch disk.
I have some parts that we may consider adding to the parts list:
BUMP STOPS - 99137 from Energy Suspension:
They work well with a little bit of bending at a drilling and tapping a new hole. link: http://www.energysuspensionparts.com/9.9137
The second product is another bump stop, but these go to the front:
BUMP STOPS - 99103 from Energy Suspension:
These work great to add what is close to the original bump stops on the front diff. They go on the two steel plates that I was very confused about when I cleaned and painted the front axle. On my second patrol they still had them bump stop glued on. To make these work you need to drill a hole in the two steel plates you took of the front diff. then weld on the a nut that doesnt have the plastic in it. take 3 large washers that fit over the nut and screw the bump stop down tightly. finish by hacking off the protruding threads and grinding flat. Spray paint the washers black to bring the look together.
http://www.energysuspensionparts.com/9.9103
I found that my Virus protection was blocking my uploads, So I`m going to start posting pictures!
Questions for the board:
Does anyone have a good replacement for the rear brake/turn lights?
Can someone way in on how I should route the fuel line? I have 3/8 bendable copper hose, but honestly can`t figure out the best way to route it.
Now that I can update pictures I`ll provide some more and hopefully better updates!
Today I got sheet metal for the Patrol. I had them bend up two of the body mounts for the bed portion where it ties into the frame in the front. I am hoping that someone can post a picture of what the front section of the bed should look like. As you can see in the attached image, mine was pretty much entirely rusted away.
On the successful part of today I bought a chop saw to help turn the metal that I have into usable patches for the partol. I used energy suspensions 1/4" pads and cut 1/8" steel to recreate the mounts. I don`t have a drill press so tomorrow I am going to drop the 2x2" blocks of 1/8" steel at a machine shop to get a hole drilled into the center.
KyleAnschuetz wrote:Today I got sheet metal for the Patrol. I had them bend up two of the body mounts for the bed portion where it ties into the frame in the front. I am hoping that someone can post a picture of what the front section of the bed should look like. ...
Hope this one helps. The picture is not mine.
Hello fellow Patrol`ers,
Does anyone have any idea where I can find the fuel pump fittings? I am having no luck finding fittings that I can use onto the mechanical fuel pump that I purchased off the parts list.
Thanks,
Kyle
They shouldn't be too hard to find. I've seen them at auto parts stores before.
Been thanked: 95 times
Post by yuke175 »
Looks good man!
Pleasure to meet you the other night...
Been thanked: 1 time
Post by Mitch197 »
Kyle, where did you send the p40 to be rebuilt? I know there are companies that rebuild the p40 but they are more of a industrial application. Thanks and good luck on yours
Mitch,
The Nissan`s have a P engine. The P40 is essentially the same engine with a different exhaust/intake combo. There are detailed threads in the mechanical section that break that information down part by part.
That being said. I had mine done at a local Engine shop. They were:
Leedy Automotive in York PA
the total price was around 3,200$. Mine ended up needing all new valves with hardened seats and bored with oversized pistons put in.
The project has slowly been progressing as i deal with one rust patch after another and the headaches of aftermarket body panels. The Troa body panels really deserve a post of their own, but if you care my gallery has some of my thoughts on the panels (some are better than others).
Back to what is important, updating this amazing board on what I have completed and some of the questionable changes to my Patrol (that really should have gone to the scrap yard.... :violin: )
I was very frustrated after removing the rear panels and patching the tub to find out how poorly the Troa rear panels were. I ended up having to cut almost everthing except the stamped portion of the rear. I made a frame out of angle iron and some scrap I had lying around.
5959
Then I filled the gap with mig tack welds until I had a bead and what looked like a reasonable line up. The area was ground down and then hit with primer.
5957
That being taken care of it was time to remount the license plate mount, but the original license plate mount didn`t match my '72 plate. :snooty: I ended up making my own license plate bracket out of more scrap.
5953
5954
Now I couldn`t find a stock rear light, so I gave up and bought a bunch of after market lights. I think the jeep TJ ones provide a nice look and replace the need for a seperate dedicated license plate light :shifty:
Tomorrow I will mount the rear lights, and post a picture for some to admire and others to scoff at. The next big issue is to repair the rear doors and get them back into decent shape and mounted. this is a back to front type of project.
I wanted to also provide some updates on rust repairs. Hopefully some of the answers I came up with will help others to save some rust tubs.
5960
This is how I repaired my rusty rear body mounts and tub. The square tubing really does work well for a decent fix and it is very rigid.
5955
This rusted out area was patched with careful grinding and cutting. I used the Troa door jamb, but it was off and the bends were sub par. Do yourself a favor and just use a metal brake to match the part.
Oh and here is front of my Patrol:
5956
