1966 Patrol Rebuild
zed
Has thanked: 201 times
Been thanked: 677 times
Re: 1966 Patrol Rebuild
Post by zed »
My J13 has the same part
[url][https://www.carpartsmanual.com/datsun/pickup-1965-1972/engine-1300-(j13)/manifold/url]
The collar gives the manifold a tight fit to the head.
Keith
zed wrote:My J13 has the same part
Keith
In addition to Keith's comments, it will help preventing the manifold gasket from blowing in the long run. Could be installed without, but you'll have to keep an eye on tightening the bolts once in a while.
Has thanked: 28 times
Been thanked: 31 times
Post by poinrobe »
So I am going to resurrect this thread. It's been over year since my last post. But I haven't given up on the project. The motor has been rebuilt now it runs and I plowing through in the body work. Waiting for the temperature in my shop to rise enough to be able to spray primer. Today's question is if anyone know if a set of 65 Patrol doors will work on a 66. They look similar but the the handles are different. Before I make the 5-Hour drive to pick them up I wanted to see if anybody knows if they can be installed on my 66 without difficulty. I assume the hinges will work fine. My question is if the latch / lock assembly will work. Thanks!!
Has thanked: 7687 times
Great that you're making progress! Sorry, the doors are not interchangeable from '65 to '66. Different latches entirely, can't be swapped over to work. Save yourself the trip.
Post by poinrobe »
RiverPatrol wrote:Great that you're making progress! Sorry, the doors are not interchangeable from '65 to '66. Different latches entirely, can't be swapped over to work. Save yourself the trip.
Thanks for the heads-up. Exactly the info I was looking for.
Post by poinrobe »
So apparently, the doors I was hoping to acquire won't work for my 1966. Does anyone have a set of doors that they are willing to part with?
Has thanked: 225 times
Been thanked: 115 times
Post by Edgar »
Will doors from a '67 work on a '66? If so, I may have an extra set I won't be using.
Yes, doors from a 67 will work on a 66.
Has thanked: 514 times
Been thanked: 631 times
Post by rdarnell »
I found replacement latches for the bodu on my 1967 but the star wheel on my doors was equally screwed up so I am planning some modifications in the future... unless I find some better hardware pieces in the future. It would be easier to maintain the original setup over doing custom.
Post by poinrobe »
So project continues slowly but steadily. I have completed much of the body work and now I am starting the door fitting process. I Have a quick question for you all. All four of my door hinges have a slight bend to them. Does anybody know if this is intentional or the result of wear and tear. I can easily straighten them out but before I do want to make sure that they are indeed supposed to be straight.
