Page 5 of 5
Re: Bolt on Bolt off Front Disc Conversion Bracket
Posted: Thu Sep 12, 2024 9:39 am
Great write up! Thanks for sharing!
:clap: :clap: :clap:
Posted: Wed Sep 25, 2024 4:50 pm
by jwgreen
Peter60,
Thanks for the write up and the feedback, I appreciate both.
As for the fronts not locking up, you should be good with a 1" especially with a booster, you may need to adjust the pedal or check that the booster is working correctly. Another member installed a aftermarket 1" and it is working great after it was adjusted correctly. You can go with a larger bore if all else fails.
On the rotors, did the machinist put a 45 deg chamfer on the back side? This is pretty critical as the hub is not a 90 deg angle where it transitions so the chamfer allows the disc to sit flush without over boring the opening.
If you need anything you know where to find me.
Posted: Mon Sep 30, 2024 3:30 pm
jwgreen wrote: Wed Sep 25, 2024 4:50 pm As for the fronts not locking up, you should be good with a 1" especially with a booster, you may need to adjust the pedal or check that the booster is working correctly. Another member installed a aftermarket 1" and it is working great after it was adjusted correctly. You can go with a larger bore if all else fails....
If the front wheels are not locking and the rears are, you'll loose control in a panic stop. In my case, even though I don't have a disk conversion, I put a limiting pressure valve for the rears when I installed my brake booster. Works very nice.
Posted: Tue Oct 01, 2024 2:46 pm
by jwgreen
Esteban wrote: Mon Sep 30, 2024 3:30 pm
You are very correct Esteban, as always, the rears must be adjusted as well to get the entire system working well. I hear it takes a lot of work to adjust those rear drums correctly.
Posted: Fri Nov 01, 2024 8:05 pm
by Peter60
Hi Justin. Sorry for late reply I have been travelling for the past 6 weeks.
Re:On the rotors, did the machinist put a 45 deg chamfer on the back side? This is pretty critical as the hub is not a 90 deg angle where it transitions so the chamfer allows the disc to sit flush without over boring the opening..
Yes. He put a 45deg chamfer on it. They fit perfectly.
Re Fronts disc not locking. I think I just need to do some adjustments as you suggested. I'm happy with how they work - much better than the drums - it's just I expected them to lock up. I should have time to look at them next week. I plan to pull them down and inspect them thoroughly to ensure all are aligned etc. I' not expecting any issues.
Posted: Sun Dec 08, 2024 7:15 pm
by Stetaylor2061
Will the disk brakes work with 16 inch OEM wheels?
Posted: Wed Dec 11, 2024 8:53 am
by jwgreen
Stetaylor2061 wrote: Sun Dec 08, 2024 7:15 pm Will the disk brakes work with 16 inch OEM wheels?
Unfortunately I do not believe they will. I on using aftermarket rims, I will try to post up the info on them a little later.
Posted: Thu Feb 05, 2026 6:43 am
by SLYLSG60
A little post on these, received my brackets a few days ago, so I though it post some of my info for those that may need it.. Probably more helpful for the Australians on here as thats where im posting from,
Front end disc brake conversion brackets arrived today, just waiting on the rotors to come back from the machine shop to fit them all up.. 👌🏼
Along with all new wheel bearing and lock nuts & washers
Below is my list of parts, info, and links
Parts List
The links are where I got these items, you may be able to source elsewhere.. Obviously you don't need to do your wheel bearings if yours are in good condition, but as I had no idea how old mine were and they had to come off anyway I decided to do them at the same time, also all my wheel bearing nuts had taken a beating over the years so Im replacing them as well.
Brake Conversion Brackets Pair:
Link: https://www.60patrol.com/forum/memberli ... ile&u=1141
Calipers Pair:
Part Number: RH 18-4208 and LH 18-4209
Link: https://www.amazon.com.au/dp/B07Z37V5M4?th=1
Rotors Pair:
Part Number: DR12249
Link: https://www.ebay.com.au/itm/256129096950
Now you need to get these machined, the centre hole needs to be made bigger to approx 107-108mm and have a 45 chamfer on the back to fit snug on the hub, I suggest taking the rotors and hubs to a machine shop to get them machine and test fitted so they are perfect
Brake Pads Set:
Part Number: RDBS728A
Link: https://www.ebay.com.au/itm/186216100062
Banjo Bolts x 2:
2 x M10 x 1.5 x 33.9mm Long
Link: https://www.ebay.com.au/itm/396758886015
Wheel Bearing & Swivel Hub Kit: 1 kit has everything you need
https://www.ebay.com.au/itm/135326503155
Wheel Bearing Nut & Washer Kit (you need to order 2 to do both sides) - Says MQ to GQ 1995 but seem to be the exact correct size for me 1972 G60.
Link: https://www.allfourx4.com.au/Wheel-Bear ... 23145460K/
54mm Hub Nut Socket: Makes it way easier to undo and do up the nuts.
https://www.ebay.com.au/itm/122105369722
Brake Lines:
I haven't got these made yet
But going by the forum post you will need 2 x 400mm long brake lines made up, be sure to get them made with the correct size and type fitting that matches the fitting on your current lines on one end and the other to suit the banjo bolts.
I will post more photos as I install the rest...
Also, obviously you will need to upgrade your master cylinder if your already haven’t, there’s more detail about this on the forum from those who have already done this conversion.
Hope this helps anyone looking to do the upgrade, hopefully we see more shared info on here..
Posted: Sat Feb 07, 2026 11:03 am
Great information! Thanks for sharing!
Posted: Mon Feb 09, 2026 3:36 pm
by jwgreen
Sorry it took me so long to reply to this, but here are the wheels that fit with this conversion.
Specs:
Brand: Wheel Vintiques
Manufacturer's Part Number: 12-660604
Product Line: Wheel Vintiques 12 Series Smoothie Wheels
Summit Racing Part Number: WVI-12-660604
Wheel Diameter: 16 in.
Wheel Width (in.): 6.00
Wheel Size: 16x6
Wheel Bolt Pattern (application): 6 x 139.70mm / 6 x 5 1/2 in.
Wheel Material: Steel
Backspacing (in.): 4.00
Offset: +12.00mm
Lug Nut/Bolt Seat Style: Conical seat - 60 degree
Hub Centric Ring Compatible: No
Center Bore Diameter (in.): 4.25
Center Bore Diameter (mm): 107.95
Link:
https://www.summitracing.com/parts/wvi-12-660604
