Got the good used fuel pump installed (after fighting with the flare fitting and nut on the outlet of the pump, thought I'd never get them lined up so the nut would thread on
There is an exhaust leak where the exhaust manifold bolts up to the bottom of the intake manifold......sigh. So the intake and exhaust will have to come off to fix that. Will rebuild the carb at the same time. The heat riser is froze up too, so that will have to be addressed too.
Brought the beer keg gas tank home to clean it out with the pressure washer. Eventually I'll replace it with a poly Bronco fuel tank but that's lower on the list than other stuff.......like the exhaust leak, brakes, tires, etc.
Topped off the radiator with a gallon of antifreeze, and the coolant is circulating and no leaks and/or strange noises out of the water pump.
With it running, got in and pushed the clutch in and the transmission easily went into gear, so the disc isn't stuck to the flywheel at least.
Pulled the brake master cylinder off and brought it home, but it looks DOA. Not sure if it will even come apart, and honestly I don't see a need to waste time on it, just order a dual m/c.
Not sure what the next step in the project should be. The current location of the Patrol is not conducive to putting it on jackstands to work on the brakes, but I could put it up under the carport where there is a concrete slab. The brakes will be a huge job, including replacing the metal brake lines. Another option for the next step is to pull the intake/exhaust, regasket everything, and rebuild the carb. If I do that, scope creep will rear it's ugly head, and I'll have to make a new exhaust header pipe and put a new muffler on. Haven't done a search yet, but guessing that pre-bent exhaust systems are not available in the US for Patrols. But it looks like it should not be difficult to have an exhaust shop bend the header pipe up, and bend a muffler outlet pipe so it exits in front of the rear tire.
Question: what what is the purpose of the four shims sandwiched between the m/c and the firewall? They show in the parts catalog so they are factory original. Only thing I could think of is to reduce how far the m/c pushrod pushes the m/c piston.
