Been thanked: 46 times
Post by IrishPatrol »
Wow, i lost what Appeared to be a lot of oil yesterday when trying to get the valve cover sealed. Still registers high. I will take a pic of the dent in the oil pan and we can see if theres a math matician out there who can asses the volume....could be fun... Right? I Sure am glad some one created this thread... Its like they had me in mind.
Her is a pic of the oil pan dent.. any guesses on volume?
Has thanked: 6022 times
1/2 pint. Final answer
Has thanked: 7718 times
I'd say a half quart. :think:
When I first found the dent i thought it may be interfearing with the oil pick up tube or the pump. doesn;t seeb to be the case oil preasure seems to be fine. Gets to the top end ok. havent had the pan off to look for sure. When I do i'll try to take out the dent.
Been there, done that. Someone else was driving my Patrol and caused a dent and I had to drive it out of a canyon then 50 miles back home. I smelled burning oil the whole way. I guess I was getting some blow-by because the engine was overfull with oil due to the dent. The dipstick read way overfull. I pulled the pan off and beat out the dent, but it wasn't easy. The oil pans is reinforced on the bottom. :roll: Put the pan back on and it was all good, even with the little chunk missing from the engine block. :?
Has thanked: 12 times
Been thanked: 36 times
Post by sleepyzzz »
what happened to the skid plate? i would be looking to add one of some sort
1967 SPL 1600
2013 Nissan Rogue
2001 Nissan Sentra SE R
sleepyzzz wrote:what happened to the skid plate? i would be looking to add one of some sort
They don't all have skid plates. Only a few. And the skid plate mounts changed over the years so they don't interchange. :|
Ok now I want one!
Ok new question, what type of antifreeze should we be using in the 60 series Patrol. There is a lot of new stuff out there. After reading a little bit on if it really matters, Apparently it does.
