Page 54 of 58
Posted: Mon Mar 27, 2023 7:50 pm
As far as I know - be sure to save the old one. I think it's actually 2 pieces; one flat and one triangle shaped to fill in the gap. It might all be one piece.
Posted: Mon Mar 27, 2023 7:58 pm
by jwgreen
RiverPatrol wrote:As far as I know - be sure to save the old one. I think it's actually 2 pieces; one flat and one triangle shaped to fill in the gap. It might all be one piece.
River, I have no clue if I still have those!!! I took that apart many years ago!!! Guess I will need to do some digging to see if I can find them somewhere... :think: :think:
I couldn't find a good picture of it in the parts book....
Posted: Mon Mar 27, 2023 8:33 pm
jwgreen wrote: River, I have no clue if I still have those!!! I took that apart many years ago!!! Guess I will need to do some digging to see if I can find them somewhere... :think: :think:
I don't ever recall seeing any kind of picture of it.
Posted: Wed Feb 14, 2024 6:00 am
by Peter60
How hot does the gearbox/transfer case get?
I just put in a 3 speed box as my Marks 5 speed is out for repair. When I was checking for oil leaks after a half hour highway drive (2WD) I noticed the gearbox and transfer case were hot.. I could touch them but they were hotter than I expected. Is that normal? It is summer here so the day temperature was 28c (80F). They did have oil in them.
Posted: Wed Feb 14, 2024 7:06 am
Peter60 wrote:How hot does the gearbox/transfer case get?
They do get hot as you mention. Probably 40C (105F) at least.
I found a temperature log from when I rebuilt the rear differential. I think it does gets hotter than the transmission, but the transmission also gets some influence from the engine.
Temperature at the body of the differential: 140F (60C) - ambient temperature: 50F (10C)
Temperature at the cover: 116F (47C)
Temperature at the Transfer Case: 128F (53C)
The temperatures were taken after 20 miles (32 Km) of driving.
I do have one reading taken after 65 miles (104 Km) of driving at highway speeds, and the differential body was at 134F (57C), but the transfer case was at 160F (71C) :shock:
I should take some more readings!
Posted: Wed Feb 14, 2024 11:19 am
Only Esteban would have a log of temperature readings on his transmission. :D
Posted: Wed Feb 14, 2024 3:22 pm
by Peter60
Thanks Esteban. That's good to know. It's something I have never thought about. I should take some temperature readings a well.
Posted: Wed Feb 14, 2024 5:17 pm
Peter60 wrote:Thanks Esteban. That's good to know. It's something I have never thought about. I should take some temperature readings a well.
I always use an infrared thermometer to check some things in car. And the reason I took the readings of my differential was after the rebuilt I did. Previously, a strange noise was coming from that area. The thermometer revealed a very high temperature of the pinion bearing closer to the U-joint. After the repair, and since I did all the gear contact calibration, I was concerned about it, and was monitoring the temperatures.
I haven't taken readings in months, however.
Posted: Thu Feb 15, 2024 11:23 am
by Sconnierider
Does the wire that goes to the thermostat branch off from the wire loom that goes to the alternator? I found the thermostat but it has no wires attached? I see a pale yellow wire that isn’t attached to anything but does appear to be long enough to attach to it.
Posted: Thu Feb 15, 2024 11:31 am
Yes, that yellow wire is the wire to the temp sender.
