I thought I would use snaps along the top horizontal but then velcro or fastex "D"'s or buckles as to cinch a bit, expansion/contraction happens. I should mention I have had plans to make tan vinyl sides and rear panels with 20 gauge clear vinyl windows. They could velcro or snap onto bottom edge of the vinyl, lapped. My goal here is to keep the majority of rain out.
This rod runs through a length of tubular webbing sewn underneath and utilizes the existing hardtop mount holes.
The way it is looking it should work even to drive at slower speeds. I started to wonder if it may be better to use 1" webbing with a fastex adjuster right down to the outside of the tub. These vert straps could then be on the outside of the side panels keeping them tight also. The vert strips seen are just backing in prep for some webbing.
The big Q is.....will the vert strap flap like crazy or just a bit?
