Wheelcylinder piston rubber part number#
I just picked up 6 from the dealer for my 69 patrol ( the last six in the U.S; I was told ) these are the rubbers that come in the rebuild kits already mounted on the piston. However you may be abel to get them from a Austrailan parts store or dealer; club . part number #44112-E5010..................This is the cheepest way to go at $2.77 apeace U.S....hop this helps jerry - aney one got leafsprings for 69 patrol.
>>I just picked up 6 from the dealer for my 69 patrol >>( the last six in the U.S; I was told ) these are the >>rubbers that come in the rebuild kits already mounted >>on the piston. Ive never had the cylinders apart, thus, are you saying that these pistons will work on both the front and rear cylinders? >>However you may be abel to get them from a Austrailan >>parts store or dealer; club. If not you can get the rebuild kits, at least you could as of a week ago >>part number #44112-E5010.................. Roger. Only Q left is if these are good for both front and rear. >>This is the cheepest way to go at $2.77 apeace U.S....hop this helps jerry Depends, in that the rebuild kit gives you the dust covers too, and everything else. Sliping the new rubber on the old piston is not hard to do at all. And the piston is hardly ever the part the goes bad, the cylinder is the part that usally goes bad and needs to be honed out. But sometimes they are so pitted that they cant be saved. Thus the *cheepest* route is to pull them off, take them apart and give them a look to see if a rebuild kit will work, or if you need new. But if you factor in your time as part of your cost then the *cheepest* route may be just to buy new right off the bat, and save the olds for spares. >>- aney one got leafsprings for 69 patrol. See my post in the suspension section, there are two places in Aus where you can get leafsprings. And, last I check NISSAN still had stock ones for... for... Hmmm, I forget, I think it was the front. Well one or the other anyways. Grant
For me this was the way to go . The rubbers will work front or back cylinders; the pistons are differant front and back but take the same rubber. As for the dust covers thay cost about $3.00 apeace from the dealer . If you are going to rebuild your cylinders I would use 600 grit wet& dry sand paper for the rears and cylinder hone for the fronts .The rears are aluminum. I had to buy one cylinder. Rebuilding the cylinders is really easy just look for pits and unusual wear. You should also with any rebuilt cylinder 'pull your wheels off after a few days of driveing and check for leaks' as the 69 patrol has a signal master cylinder .( only one resevor for front and back).....Jerry
>>For me this was the way to go. For most I'm sure, these PATROLS are a labor of love, a tinker paradise. But for me, I didn't have the time to tinker, so I went new. Because with my luck I would have had one bad one like you anyways. >>The rubbers will work front or back cylinders; the pistons >>are differant front and back but take the same rubber. So.. these things you bought, were they a piston with rubber, or just rubber? Because when I first read your message I got the impression that it was a piston with rubber. >>As for the dust covers thay cost about $3.00 apeace >>from the dealer. I got the whole rebuild kit for the rears, had to get them from Aus, but I think they were only USD $8.00 or so. Has the rubber, dust cover, etc. I recommend you wait to get a big order to make the shipping worth it all. >>If you are going to rebuild your cylinders I would use 600 grit >>wet & dry sand paper for the rears and cylinder hone for >>the fronts. The rears are aluminum. Huh, your rears are aluminum? Mine are not. I have a 67. >>I had to buy one cylinder. Ding! >>Rebuilding the cylinders is really easy just >>look for pits and unusual wear. Yeah, but, most of the time the leaks are due to pits, and the odds are they will be too deep to hone out. Thus my opinion that it is cheaper to bite the bullet. Unless you have all the time in the world, and love to tinker, and find tinkering to be a form of therapy!
>>You should also with any rebuilt cylinder 'pull your >>wheels off after a few days of driving and check for >>leaks' Not a bad idea even with new cylinders! >>as the 69 patrol has a signal master cylinder . >>( only one resevor for front and back). All the PATROLS sold in the US had single masters. Say, do you have any leads on the rubber hoses that go/jumper from the metal break lines to the wheels and axels themselves. Mine are dry rotted bad, and the NISSAN dealer is having problems finding new ones. Thus you know of any after market ones that work? Grant
- Been thanked: 1 time
Grant, Here are some NAPA part numbers for the five hydraulic hoses necessary on the patrol. Thanks to my local NAPA guy Randy, who did the research for me. Front Wheels - Napa United 11190 (two required) Front Axle - Napa United 5784 (about 1/2" shorter than stock) Rear Axle - Napa United 5784 (about 1/2" shorter than stock) Clutch Slave Cylinder - Napa United 36507 Good Luck! Rick G
RickG! Thanks You So Much! Im planning a road trip from Las Cruces NM back to Redondo Beach CA in about 3 weeks and these hoses were a big worrie of mine! They are dry rotted, cracked, chipped real bad! I just had the breaks done and the guy could not find them to replace them, so this will make my trip much nicer! Thanks again!
Grant thay are just rubbers and are still available through Automax nissan. I was going to go with knew cylinders but just for the front four thay wanted $200. By th way I just got 6 more from Automax ; My e-mail order to Automax was returned by the post master so I thought my order was not getting through but weeks latter today I got deliverd the six from Automax witch I don't need .So if any one needs some $2 apeace .By the way Grant how do get your part from Austraila? I'll be doing a rebuild on my engine too if I come across any knew valve springs I'll let you know. Jerry
>>Grant thay are just rubbers and are still available >>through Automax nissan. Ah, ok, that makes sense. Thought it was strange selling the piston. >>I was going to go with knew cylinders but just for >>the front four thay wanted $200. I was just glad I could still get them! The rear cylinders I had to get from AUS, and they were a bit pricy. >>By th way I just got 6 more from Automax ; My >>e-mail order to Automax was returned by the post >>master so I thought my order was not getting through >>but weeks latter today I got deliverd the six from >>Automax witch I don't need .So if any one needs >>some $2 apeace. Hate it when that happens!
>>By the way Grant how do get your part from Austraila? Well there is a place online, there are probally more, but here is one. http://motorcare.com.au/ They carry limited stuff on the PATROL. NISSAN stopped selling the G60 PATROLS in the USA in 1969, but sold them in AUS up until 1979 or 1980. Thus AUS has a few more, thus a few more part stores that still cater to the PATROL. >>I'll be doing a rebuild on my engine too Well, there is a place here in the states that still has the engine parts. http://www.motorpowerinc.com/pricing/p40.html Thing is when NISSAN stop selling the PATROL in the states, they keep on using the PATROL "P" engine in thier industral forklifts, up into the mid 80s I belive. From what I understand the PATROL "P" engine is very simular to the forklift's "P-40" engine. The only thing they changed was the oil filter housing was made part of the block, so they could use the modern screw on type of oil filter insted of the cartarge. And it had a non waterproof distributer. And Im not 100% sure, but it sounds like the lifters in the "P-40" are different then the "P". Another thing I think is different, but not sure if the "P-40" has a timming chane with different crank and cam gears, where the "P" had not chane and gears that meshed. >>if I come across any knew valve springs I'll let you know. Thanks! Im hoping I can get them ASAP! Grant
Automax? Who are they? Where are they? I would be willing to buy some wheel cylinder cups if you are selling them for $2.00 each. Email me! jeepcj_6@yahoo.com -Jeff
