Help!!
Locked
Help!!
Post by npca-crystal »
We just recently gave my 68 nissian a tune up, new wires, plugs.cap,rotor, etc.  just a bout changed everthing on the thing to newer stuff and the darn thing runs like crap, my other half is about to burn it to the ground. can anyone tell me what the gap in the points are supose to be I have a book and it says between 18 and 22. the thing idols real good as soon as you get out on the highway the thing starts to spit and sputter. we then drained the fuel tank and a end piece of the old gas cap was in there so we removed it. not the problem , tore the carb apart and rebuilt  it not the problem . He's about ot go crazy  ther is not much on the thing so please help!! crystal
Been thanked: 1 time
Help!!
Post by npca-jeepy »
Obviously, it can be many things. First of allcheck the dwell angle and then the timing sinceyou replaced the points. Was it running goodprior to the tune-up? It is possible that thereis some other problem with the fuel deliverysystem but it is most likely ignition since thatis what was tinkered with. Try that and see whathappens. Let me know. Sorry about the other 3messages. My computer went hay-wire.-Jeff
Help!!
the truck was running good then all of a sudden the thing was running on only 5 cyllinders the we gave it a tune up. thats when all hell broke loose. we then re timed it to 10   rechecked the points then we  checked the gap in plugs basically  we've done everthing. thats why we need  help.  Ill tell you what I mean by crap.  when you excellerate the thing goes and slowes and then goes and slowes like its not getting gas. blew the line out during the fuel tank clean  out . Still dazed and confused !!
Help!!
Post by npca-alex »
Not to sound stupid or anything, and this is obvious enough that you probably already did it, but double check the firing order and make sure the wires are correctly hooked up, I once was present when a guy fired up a toyota he had just tuned up and got the wires in the wrong order on, talk about running like shit.
Help!!
Post by npca-viking »
I am confused a tad. In one message your engine was running fine before the tune-up. In another you were running on only five cylinders - and hence I presume this provided the incentive for the tune-up. If the latter, you must establish what caused the one cylinder to stop firing. It may have been something more than ignition components that were failing. Have you done a compression test to ensure valves and piston rings are doing their thing?
Help!!
Hey thanks you guys for all your input.I think we have a blown head gasket. Let you know when we tare it a part. Thanks again  Crystal
Help!!
Post by npca-sehismith »
When you tear your engine apart, could you photograph it for the Club? Those photos could be invaluable for us in the future. If you have only prints, you can send them to me to scan in. Let me know. Thanks, and good luck! Steve
Locked
