parts
Posted: Sat May 07, 2005 2:52 am
by npca-driver dave
I hope someone can tell me where I can find a gasket set and a bottom rad. hose with the heater hose fitting in it . Thanks.
parts
Posted: Mon May 09, 2005 11:19 am
by npca-bigwave
You will have to fabricate the lower radiator hose with heater core hose in it. Just get a regular radiator hose to fit, cut it near the same location your old hose had the heater hose coming out, and insert a piece of exhaust tube that is the same diameter as the inside diameter of your rad. hose. Drill a hole in the pipe you placed between the two pieces of radiator hose and weld a nipple that fits your heater hose size. It is more or less a home made "T" to tap into the lower radiator hose. If you need a picture, drop me an e-mail, I would be glad to help. David Collins Hood Canal Communications
parts
Posted: Tue May 10, 2005 1:25 pm
by npca-abuelo442
The radiator hose I purchased at Advance Auto Parts, 70623CS (they let me browse through the inventory and I picked this one 1-3/4" i.d.) and cut to length. For the T connector/diverter from the radiator hose to the heater, I used a combination of copper Tees and reducers. I even used the epoxy stuff instead of welding, and it's been working great for 6 months by now. I can send you a couple of photos that shows the adaptor and the hose in place. Esteban
parts
Posted: Wed May 11, 2005 1:22 am
by npca-joel
What a great find. I'm fighting the exact same problem today. I found a hose that fits but couldn't figure out how to make the heater hose connection. You guys have some good ideas. Would appreciate pictures of your fixes.
joel.suty@att.net
