Head work
Posted: Thu Feb 06, 2003 5:38 am
by npca-joeys
I am about to purchase a Patrol that smokes. I was told that it needs head work, and that is the "smoking problem"   Anyway, where is a good source for rebuild parts fo rthe 1969 P40 engine?
Head work
Posted: Thu Feb 06, 2003 6:10 am
by npca-pudde
before tearing it apart....go for a ride...see when it smokes...on take off....coasting...decel downhill?......what color is smoke?......check oil..see if its clean?..see if water in oil or oil in water?...check spark plugs..see which one is oil fouled....maybe just a stuck valve or carbon buildup on it?....way to many things to look at before you tear it apart....and by chance,if its apart then...take to a machine shop...let em check it out...parts resources are on site here.   my patrol smoked a bit when i first got it....i just changed filter...changed oil...and i went with mobile-1 synthetic(15-50)...after a few weeks of running and driving..no more smoke...but oil was VERY dirty..changed it out...new filter and oil...(synth again)..and all is great!...tell us what you find...:)) paul   ps...my motor has never been rebuilt..or touched...and has 90psi oil pressure on hiway...45-50psi idle at temp around town..no leaks.valve adjustment coming up soon :)
Head work
Posted: Thu Feb 06, 2003 5:02 pm
by npca-joeys
I will have to play with it when I get it.   I used to own a 260z with the 2.6 L I-6, and it would smoke pretty bad until I changed the oil with Mobil-1, wire-brushed the plugs (all of them were pretty bad) and ran 93 octane plus an Octane booster for 3 tanks. AFter the 3 tanks, the 4 5 6 plugs were covered with carbon, not oil, but I didn't have that problem again afterwards.
Head work
Posted: Fri Feb 07, 2003 10:29 am
by npca-chris
; Joey,;     Motor Power Inc. was able to get me the majority of ; parts for my rebuild.  Danny is the guy there that I have been dealing ; with.  He has PPU engines parts that are almost identical to ours.  ; Their phone number is 800-356-7948, and their website is www.motorpowerinc.com ; .;  ; Thanks; Chris;
Head work
Posted: Sat Feb 08, 2003 2:36 pm
by npca-joeys
Thanks
