spark plug wires
Posted: Thu Mar 28, 2002 5:04 pm
by npca-stahlhaang
Any stock spark plug wires out there for a 69 KL60? My distributor cap is the screw on kind, and I'd be more than willing to go to a push on if necessary. Also, what is the gauge of the wires?
spark plug wires
Posted: Wed Apr 03, 2002 3:06 am
by npca-swede
I have the same distributor cap and the 2 times I changed my wires I just took the distributor cap and wires to the parts store and they have generic kits that will fit. All you have to do is cut the lenghts and put some "metal ends" on them. When you push them into the distributor cap you should also use a special "grease" that increases the contact and life span. The distributor cap and rotor is still available through Nissan, let me know if you need the part numbers
spark plug wires
Posted: Mon Dec 09, 2002 10:06 pm
by npca-river rat
HI THIS IS RIVER RAT I JUST JOINED THE CLUB AND READ YOUR MESSAGE. YOUR WIRES, CAP AND ROTOR YOU CAN BUY AT YOUR LOCAL NAPA PARTS STORE. I DONT HAVE THE PART NUMBERS WITH ME, BUT WILL POSST THEM THE NEXT TIME IM ON LINE.
spark plug wires
Posted: Tue Jan 14, 2003 3:26 pm
by npca-drews67
Hey there, I went to my Napa parts store just the other week for plugs and wires for my '67, they didn't have anything for the wires, and they had to order the plugs. I need new wires badly. Can you get the parts number River Rat? Thanks -Drew
spark plug wires
Posted: Tue Jan 14, 2003 3:53 pm
by npca-hoss
I BOUGHT A UNIVERSAL SET FOR 6 CYL YOU CUT AND PUT THE ENDS ON YOURSELF TO THE PROPER LENGTH. NO BIG DEAL .
spark plug wires
Posted: Tue Jan 14, 2003 4:41 pm
by npca-danetteandkeith
I recently pulled my dist. cap off and redid the ends of the plug wires. I had a terrible miss at times. One day it ran fine the next it would cut out and die.(Usually when my wife was driving it) The end of the wires were burnt up. I trimmed just enough so that the center of the wire was sticking out. My wires didn't have metal ends on them. The dist. cap has sharp spikes sticking up that go into the wire when you push them in. Then the rubber collar and sleave press against the dist. as you screw on the caps for the wires. It is like a compression fitting type thing. Ya'll talk about cutting new wires and putting a metal end on them. Should mine have metal ends? Anybody know? Keith P.S. I no longer have a miss. Purrs like a kitten.
