G60 Tune Up Info and Parts
ELECTRICAL (NEGATIVE EARTH)FIRING ORDER 1-5-3-6-2-4IGNITION TIMING 10°/450 rpm B.T.D.C.DISTRIBUTOR CONTACT ARM SPRING TENSION 0.50 ~ 0.65kg BREAKER POINT GAP 0.45 ~ 0.55 mm (0.020") DOWEL ANGLE 35° ~ 41° (point gap 0.5mm)SPARK PLUG DIA. OR THREAD 14mm REACH OF THREAD 19mm DIA. OR HEXAGO 20.6mm SPARK GAP 0.7 ~ 0.8mm (0.024" ~ 0.028")D.C. GENERATOR & REGULATOR CUT-IN VOLTAGE 14.5v AT 1600 rpm NO LOAD VOLTAGE 15.5v AT 3000 rpm PUSH UP VOLTAGE 9~11v AT 3000 rpm BRUSH SPRING TENSION 0.36~0.5 kg BRUSH HEIGHT (STD) 16mmSTARTER MOTOR BRUSH SPRING TENSION 0.9 kg BRUSH HEIGHT (STD) 16mm TYPE 1 TYPE 2 TYPE 3 -----------------------------------------------------------Distributor 1 22100-43801 22100-46500 22100-44201Distributor 2 22100-46500 22100-44205 22100-44205Points 1 22145-58000 22146-43805 22146-58000Points 2 xxxxx-xxxxx xxxxx-xxxxx 22146-43805Vacuum Adv 1 22301-43801 22301-43805 22301-44201Vacuum Adv 2 22301-43805 22301-44205 22301-44205Condenser 1 22102-50001 22102-50001 22102-50001Condenser 2 22102-50002 22102-50002 22102-50002Dist Cap 22162-43800 22162-43800 22162-43800Rotor 22157-50001 22157-50001 22157-50001 TYPE 1: Dist Cap: has screw on caps for each plug wireVacuum Adv: Has threads for the metal vacuum adv lineNOTE: Dist Housing has TWO nipples/connectors for an air lines (not vacuum adv) in and out. Type 2 and 3:Dist Cap: has the typical slip on plug wiresVacuum Adv: Has the typical slip on connector for rubber type of vacuum advNOTE: Dist Housing has ONE nipple/connector for an air line (not vacuum adv). SUMMARY: None of these distributors have the typical clip on type of distributor caps, all three types have distributor caps that are screwed onto the housing via 3 screws. I thought I read or saw somewhere that someone had a distributor with a clip on type of distributor cap? Anyway, the two types of distributor caps (screw on or slip on spark plug wires) are the same size, because they have the same rotors and same part number for the o-rings. Thus you should be able to use either. PARTS FROM NISSAN POINTS (POINT-SET)http://www.nissanautoparts.com/detailli ... mit=Submit VACUME ADVANCE (ASSY CONTR) (Threaded Vacuum Line)http://www.nissanautoparts.com/detailli ... mit=Submit VACUME ADVANCE (ADVANCE-VA) (NON Threaded Vacuum Line)http://www.nissanautoparts.com/detailli ... mit=Submit CONDENSER(s)http://www.nissanautoparts.com/detailli ... mit=Submit DISTRIBUTOR (DISTRIBUTO)http://www.nissanautoparts.com/detailli ... mit=Submit DISTRIBUTOR CAP (CAP-DISTRI)http://www.nissanautoparts.com/detailli ... mit=Submit ROTOR (ROTOR-HEAD)http://www.nissanautoparts.com/detailli ... mit=Submit Grant
Hey Grant, Is this info for the "P" engine? Your Subject line says G60 is that the same as KL60 or is this info for the newer Patrols? Don't mean to be nit picky,just wondering cause I need a new vacuum advance and was wondering if the link is the right one for the "P" engine. Thanks, Keith
Hey Danette & Keith My bad.. I should have called this message: Model 60 Series Patrol Tune Up Info and Parts Where the G60, KL60, etc are all 60 Series... to make a long story short (TOO LATE) these settings are for the Old Patrol "P" engines. Grant
; ; ; ; 1969 Patrol. Thanks you Grant for your service.; ; ; ; -----Original Message-----; From: denny; [mailto:finnsfx@msn.com] ; Sent: Saturday, May 18, 2002 7:20; AM; To: Nissan Patrol Club Albuquerque; Subject: Re: G60 Tune Up Info and; Parts; ; ; ; ; ; ; ; ; ; ; ; New; Message on Nissan; Patrol Club Albuquerque; ; ; ; ; ; ; ; ; ; ; ; ; ; G60 Tune Up Info; and Parts; ; ; ; ; Reply; ; ; ; ; ; ; ; ; ; Reply to Sender Recommend; ; ; ; Message 4 in; Discussion ; ; ; ; ; ; ; ; ; ; ; ; From: denny; ; ; ; ; ; ; ; Grant....You are the man ! Thank you !; This makes it so easy. Denny; ; ; ; ; ; ; ; ; ; ; View other communities in; this category. ; ; ; ;
