Synchronizer rings for a 67 3 speed??
Locked
Lurker
Lurker
Post by npca-cliff »
Hello,  I was wondering if anyone knows anything about how to get synchros for a 3 speed 67 nissan patrol.  Our local nissan dealer claims they don't exsist anymore......which isn't an uncommon reply, but we still need to get them.  So any info at all would be greatly appreciated.  Please E-mail me at dewriffic16@yahoo.com or post a reply.   Thanks again
Post by npca-grant »
Check out the clubs links here.   http://communities.msn.com/NissanPatrol ... ortstring=   If that does not work, check out this place, not sure but I think they may have them.   http://www.rishabsynchrorings.com/product.htm   Grant
At that sight look for:   NISSAN JONGA   In that in INDIA the PATROL is known as a JONGA, but, Im not 100% sure that the transmissions are the same. You should verify that with them, let them know you have a NISSAN PATROL and are wondering if the parts are the same.   Grant
PS let us know what you find out... if anything!   Grant
Lurker
Lurker
hey thanks a lot for all the info i will definitly look into that and tell you if  i find them thanks again,   Cliff
Lurker
Lurker
Post by npca-dewriffic16 »
Well after lots of confusion, we found our synchro rings at Nissan autoparts.com.  Our parts book has a bad number.  The correct number is 64000-80003.  Thanks for everyone's suggestions.
Hey Dewriffic   I was going to add your discovery to our COMPATABLE parts list... but the part number you listed here is not a good number. ie.   http://www.nissanautoparts.com/detailli ... mit=Submit   So, could you check that number again.... I would be very interested in the number that you said was bad too. In that Im currently scanning in the old parts book with all the part numbers, if one is wrong, Ill make a note of it. Oh, and could you be more specific, which synco rings are these? Or is it a syncro kit? Anyway, any info would be great thanks!   Grant
Locked
