AIR FILTERS
AIR FILTERS
just a quick note for those of you looking for a cheap and readily available air filter assembly.i use a ford truck 300 six cylinder filter assembly.the assembly from mid seventies up until approximately 1984 bolts right on.you can easily add a brace for little expense.also there should be a k&n filter available for this housing.you can hook up the warm/cold air intake and connect vacuum lines up to sensor to make intake flap function.you should be able to pick one of these up for practically nothing and paper filters are less than five bucks.regards;commando.
AIR FILTERS
Would you be able to post a photo of the assembily or email me one at cooki55@attbi.com?
