Replacement Distributor
Locked
Post by npca-papa1 »
Is there any other distributor that will fit the '69 Patrol? I keep frying points even though I replace the condensor. Anybody have the same problem? Thanks in advance for your replies!   Papa1
Post by npca-pudde »
make sure your running a coil that has a built in resistor.....(should say on coil..no external resistor needed...)which means theres one inside the coil....if not..your getting full 12 or more volts to points...and that will smoke em......paul
Post by npca-commando »
TO PAPA1-BE SURE TO USE A BALLAST RESISTOR ON THE 12V SUPPLY TO   THE IGNITION COIL.COIL MUST BE MARKED INTERNAL RESISTOR   OR POINT FAILURE WILL OCCUR.EASY BALLAST RESISTOR TO AQUIRE IS ONE FOR 6 CYLINDER CHRYSLER PRODUCT UP TO EARLY 70S.BE SURE TO USE BALLAST RESISTOR FOR 6 CYLINDER TO GET BEST POINT LIFE.
To Pudde and Commando   Sometimes problems are easily fixed with a refresher course.  Thank you both for the input.  This internet is all new for me.   Thanks again, Papa1
Post by npca-vladimier »
Here is the response I received when looking into the same problem, from Mr. Gasket/Mallory Distributers, with part #s   We offer 6 different distribuitors for your application, vacuum and non vacuum advance. The vacuum advance distributors are P/N 2763901 points, 4763901 Unilite electronic. Dennis
Post by npca-bjoseph »
do you have a web site for that part distributer that you mentioned in your post? you seem to know who you can get parts from .. please help with my clutch slave cylinder.. thanks.
Yeah, sorry, that was not too bright of me.   Link for the distributers (internet direct ordering even) is   http://www.mrgasket.com/mallorymain.html   And again, 6 different distribuitors for your application, vacuum and non vacuum advance. The vacuum advance distributors are P/N 2763901 points, 4763901 Unilite electronic
Locked
