limited slip, gday
Has thanked: 23 times
Been thanked: 65 times
limited slip, gday
Post by limited slip »
limited slip checking in!
names kev, im from the monaro in southern nsw Australia. pretty much like anything that's 4x4 and when not working i am usually fiddling with my 4by's, and when holiday time comes im usually driving said 4by's to some remote spot to hunt/fish/hike/camp.
currently i have 5 g60's, 2 running, 2 for "parts" and one long term project which has dragged on twice the time it should have due to finances and personal injury's:
"red six" 1976 short wheel base g60 which is actually orange rather than red, lots of little mods, stock drive line and too much rust to bother repairing, so i use her as a farm hack and do the odd bit of 4wd'ing in her, particularly rock crawling which with the 35's on she excels at.
"hermit" 1977 g60 ute, name comes from the color (hermitage 2) and from her limited use during her life with her previous owner of the last 20 years. she is my running daily driver, and sports 160 liters worth of useable fuel capacity, 5 speed mk patrol gearbox, disk brake conversion on the front and a 4.1 efi falcon petrol motor, all engineered. she is very neat and tidy and im trying my hardest to keep her that way. niggling overheating issues is the biggest bug bear atm, but ill get it sorted in time
"the last guard" or grip as i call her (the last guard against everything soft in modern 4x4's). she is my long term project which i started on about 2 years ago. the ultimate aim being to have a reliable and reasonably powerful TURBO DIESEL g60 running as my road registered work rig. she has had all the major repair work done, and has had her heart transplant. that being the sd33t motor and 5 speed box from a mid 80's mq/mk patrol. mq diff's front and rear, power steering and twin fuel tanks, as well as a fresh coat of paint sum up the way she is currently. things to do include mounting the tray. making the final engine position adjustments and making up a custom radiator, doing the wiring, installing new brake pads and shoes, and replacing the last of the worn suspension components in the front end.
both parts rigs are 72 models, one a mwb soft top ute, and the other a blue swb wagon which may eventually get all the good bits from redsix and be put back on road.
have owned heaps of various 4by's and played with double that again, but i like the old patrols, they just have some magic about them.
cheers and well done on the new site :clap:
like a gee six
Has thanked: 7716 times
Re: limited slip, gday
Welcome, and thanks. With your obvious off road and Patrol experience I'm sure that you have a lot to offer in the way of information. You should post some pictures up of your G60s, or miller or bosque might introduce you to the sisters. You don't want that, trust me.
RiverPatrol wrote:Welcome, and thanks. With your obvious off road and Patrol experience I'm sure that you have a lot to offer in the way of information. You should post some pictures up of your G60s, or miller or bosque might introduce you to the sisters. You don't want that, trust me.
the sisters?? ok noted :shock: , ill pull my finger out and post up what iv got
like a gee six
Has thanked: 149 times
Been thanked: 310 times
Post by G60michael »
Hi Kev, mate I have been thinking where is Limited slip gone, You haven't been on the forum for several months now, I Hope you are Well, Safe and doing ok, haven't herd from you or you haven't been active on the forum hope everything is ok mate.
Cheers Michael
Wow I feel missed!
I started a new job and it has been taking up pretty much all of my time. I have not really been on any forums at all for an age, just head down workin.
Big movement on the patrol horizon though, after more than a few head aches with hermits motor and/much deliberation its finally been decided to pull the 4.1 and replace it with an efi 5.0 ford v8- cause it will already pretty much bolt straight in. Once hermit is done the final work can start on grip, the gun metal grey ute I started to build nearly 4 years ago. Hard to believe its been that long.
Anyways I'm still about and well, I hope everyone here is doing as well :D
Cheers
Kev
like a gee six
Has thanked: 104 times
Been thanked: 175 times
Post by Swerve »
Welcome back Kev, :clap:
Has thanked: 351 times
Been thanked: 301 times
Post by mdawg4x4 »
Awesome assortment of 60s. Pictures are always welcome.
Your SD33T transplant would be my dream power plant. I can get one out of a 1980 International Scout here in the US. International used the Nissan SD33 for their diesel Scouts and the turbo version in 1980.
Welcome and welcome back!
Thanks for welcoming me back, I'll endeavour to pop in a bit more often now that things are settling down.
Mdawg4x4, I have pics up in the gallery already, and I have the build up of grip listed on the patrol 4x4 I think , think I have a bit of info a out it on here too?? Not sure now . Google 'the last guard' patrol build. The thing is actually back together, just need to do some final adjustments, the wiring loom, brake and clutch lines and tray. Last bit is cab fit out. :D I might have time to get it sorted in the next 6months too, which I'm excited about for sure!
Cheers for now
like a gee six
Post by duffy G60 »
Hi limited slip, I have just bought an sd33t w 4 speed to fit into my '77 G60. Can I pick your brain as to engine and box mount plate differences, firewall, diff centers, radiator etc, basically everything you can! much appreciated :D
duffy G60 wrote:Hi limited slip, I have just bought an sd33t w 4 speed to fit into my '77 G60. Can I pick your brain as to engine and box mount plate differences, firewall, diff centers, radiator etc, basically everything you can! much appreciated :D
mate more than happy to help out, ill answer any questions I can, just ask away
like a gee six
