Heater Vent hoses & fresh air intake hose
- Has thanked: 310 times
- Been thanked: 176 times
I will add a shot of the fresh air hose (3"-3 1/2" from Gates also) when I find it. This hose is not original but looks very good and close. The original vent hose was spring wrapped with canvas.
- Has thanked: 69 times
- Been thanked: 84 times
Re: Heater Vent hoses & fresh air intake hose
bosque wrote:I will add a shot of the fresh air hose (3"-3 1/2" from Gates also) when I find it. This hose is not original but looks very good and close. The original vent hose was spring wrapped with canvas.
You can use your own springs and use some of this 2" Fabric Heat Shrink Tubing it looks like canvas and it comes in 6' lengths
http://www.ebay.com/itm/JEGS-Performanc ... 4851cc2f35
Audrey
- Has thanked: 7709 times
Do you have a picture of the finished product?
I will get one! I am in the process of putting it back together.RiverPatrol wrote:Do you have a picture of the finished product?
Audrey
- Has thanked: 203 times
- Been thanked: 678 times
Audrey,
Do you have a photo of the hose?
Thanks,
Keith
Thanks,
Keith
Here are some pictures not a perfect solution. If the coil is all beat up I would not recommend this because every imperfection shows when it shrinks into the voids. You can use the fabric heat shrink just to repair over your existing hose material but you will be trapping in years of dirt. The rubber connectors are trashed on mine so I bought some hose reducers but they can get pretty expensive.
Audrey
You could wrap the new gates brand with the shrink "mink coat"!Urban60 wrote:Here are some pictures not a perfect solution. If the coil is all beat up I would not recommend this because every imperfection shows when it shrinks into the voids. You can use the fabric heat shrink just to repair over your existing hose material but you will be trapping in years of dirt.
bosque wrote:You could wrap the new gates brand with the shrink "mink coat"!Urban60 wrote:Here are some pictures not a perfect solution. If the coil is all beat up I would not recommend this because every imperfection shows when it shrinks into the voids. You can use the fabric heat shrink just to repair over your existing hose material but you will be trapping in years of dirt.
Yes! that works also
Audrey
