Radiator Hoses
Original and compatible parts
zed
Has thanked: 203 times
Been thanked: 678 times
Radiator Hoses
Post by zed »
Per Gates:
Upper
Molded Coolant Hose 20046
Cut to fit
Lower; W/O Heater
Molded Coolant Hose 20957
Cut to fit
Can anyone confirm these are correct?
Any sugestions on plumbing in the heater hose?
Thanks,
Keith
Has thanked: 7706 times
Re: Radiator Hoses
I have used a standard lower hose and added the heater hose nipple a few times. A couple times I used the original nipple and other times I used a 'T' that spliced in to the hose, actually cutting the hose all the way through.
Using the original nipple is not that hard, you just want to make sure to err on the side of too small: too big means a ruined hose. I make sure I an using an brand new blade in my Stanley knife, and I cut and 'X' into the hose. From the 'X' I cut out the 'V's to end up with somewhat of a circle. Then put the 2 pieces of the nipple together and tighten them down extra tight. Pay attention to the direction of the inlet at the bottom of the nipple; it needs to face towards the engine (I think). You can also use a light weight sealer for insurance. I have never had one leak.
Has thanked: 6017 times
Re: Radiator Hoses
Radiator Hoses
Edit:
70623CS id: 1-3/4" - No longer available
This can be used for the lower hose:
Dayco C70977 id: 1 3/4" - some cutting needed.
By-pass hose: Dayco 70637 id: 1" (also needs to be cut, but the shape is good)
At Rockauto
Upper: GATES Part # 20046 Molded Coolant Hose; 1 3/4" x 18" cut to fit
Lower: GATES Part # 20957 Molded Coolant Hose; 1 3/4" x 18 3/16" Does Not Contain Spring. W/O Heater; Cut to fit; Lower
This website allows search of Dayco hoses based on diameters and other parameters:
http://m.summitracing.com/search/produc ... ator-hoses
Adapter for heater hose:
NAPA BK 6601559
Fan Belt: 3/4"W x 48.64”L (48” nominal)
Gates 152,
Napa 25-24476 (NBH 2524476)
Dayco 24480, L:48” W: 0.75” (19mm) Angle: 38° <-------- use this
Dayco 22470, L:47” W: 0.69” (17.5mm) Angle: 38°(this one is slightly smaller in section than the 3/4", but actually works perfectly)
Edited the post since one radiator hose is no longer available and found a new one
Has thanked: 1 time
Been thanked: 10 times
Re: Radiator Hoses
Post by GARYSCC »
Thanks for all the info. my nipple is rusted so I can't use it. I found a copper tee at the hardware store that has 3/4" inner diameter in length, and 1/2" middle side outlet. I think I could make this work - but I don't want the hoses to look like speghetti. I noticed some pics of patrols that use a reducer for the bypass hose. I was thinking of reducing the 1" bypass to 3/4" tee it for the heater, then expand it back to 1". I'm just not sure how to route the hoses so it looks good.
Re: Radiator Hoses
Since I adapted the heater on mine, I'm not sure what the original routing for the heater hoses are. When I did mine, I was not aware of the adapter for the 5/8" hose, so I built the following contraption, out of regular copper pipe. I used an epoxy glue made for this purpose. Nine years and counting, perfect.
The following picture shows the components. The measurements in blue are the commercial ones, and how you order this stuff. In yellow, actual measurements.
Note: my heater is only with 1/2" i.d. hoses. Original Patrol one I think is 5/8", so you can save some steps.
And this picture, its placement into the lower radiator hose (I cut a section of that hose). Also its placement on the engine bay.
Re: Radiator Hoses
nice set up Esteban....or should I say Mr. Clean! :clap:
