What are these engine accessories?
Has thanked: 1 time
Been thanked: 10 times
Post by GARYSCC »
I noticed these items in the picture that are not on my '67 engine. I was curious what they are.
patrol engine2.pdf
Has thanked: 529 times
Been thanked: 301 times
Re: What are these engine accessories?
Post by 50car »
"A" appears that you are pointing to the engine lift point.. a small bolted on bracket..
"B" looks like you are highlighting the oil filter housing
"C" appears to be circling the old style crank case vent tube....
:D
Jeff
50Car
Has thanked: 652 times
Been thanked: 632 times
Post by Coyote Patrol »
50car wrote:"A" appears that you are pointing to the engine lift point.. a small bolted on bracket..
:D
Good job, you nailed it! NEXT! :D
Has thanked: 351 times
Post by mdawg4x4 »
I am slow, but agree!
Has thanked: 1 time
Post by GARYSCC »
ok, i feel a bit dumb now. I have the oil filter on mine - but for some reason I didn't make the connection from the picture. For the crankcase vent - did that get discontinued prior to '67 or should I have one of those on mine?
Has thanked: 7712 times
The crank vent tube was changed to a valve cover vent around '65.
Has thanked: 6020 times
RiverPatrol wrote:The crank vent tube was changed to a valve cover vent around '65.
Only in the US, and probably Australia and New Zealand. "Emerging markets" kept the vent tube until the end.
Really? I didn't know that. I am surprised that Nissan would have done this, causing them to support two different types of engines. :think: Interesting.
I see what looks to be that pipe in JimmyRobbys engine bay shot.
bosque wrote:I see what looks to be that pipe in JimmyRobbys engine bay shot.
WOW good eyes! How did you catch that? :o :shock:
