- I Originally Tried to keep the G60 Running and start it at least one or Twice a week, however when I removed the front guards to install the news one I had to wait 3 weeks for them to arrive, and couldn't start or drive the 66.
- Prior times the 66 G60 has ran like a champ, but just before I started to remove the guards I took it for a Drive and something strange happened, it was running good then all of a sudden the engine would slow down and run rough, so a little rev and it was fine again and ran smoothly.
- Once I got the guards on and went to get it out the garage It was running very rough for some reason. I had recently painted the Carby so I though paint may have blocked up a hole inside the carby,and being a Stromberg Carby I though I could use the one of the 79,however the Mixture screw was in a different spot, so I made a carby from both. Bolted up the custom carby,and the g60 started and ran to like with no visible flat spots.
- Sunday 4th AUGUST 2013
I needed to get the 66 out the shed for some photos with the new bumper and that fitted, I had to fill the bowl of the carby by undoing the top and pouring fuel in to fill it up and some down the carby,it fired up but was running like a Sick Dog to say the least, and when I went to rev it to see if it would it wouldn't do it just nearly stall and I could hear air sucking, and luckily the old girl made enough torque and struggle to pull its self into the shed in low 4, and had the choke open half way
Any idea, as I need to get it going awesome again. When i accelerate there was also no fuel sprayed into the Venturi ?
cheers g60michael
