Rubber feet for jumper seats
Parts for sale, or free
Has thanked: 652 times
Been thanked: 632 times
Post by Coyote Patrol »
Does anyone have a source for the rubber feet for the jumper seats? If not im going to make my own. :think: :pray: :roll:
Has thanked: 84 times
Been thanked: 327 times
Re: Rubber feet for jumper seats
Post by miller »
Ive got a feeling Bosque made some.. :think:
miller wrote:Ive got a feeling Bosque made some.. :think:
He he probably, guess i should ask him. I need some. :D
Just trying to humbly change the idea that "Americans won't do that kind of work" mentality......in my garage/shop/driveway! I have so many more ideas too but execution is time. Body mounting rubber is the thing I am working on now.
I remember a compatible rubber feet discussion/post.......the leg bumpers look like the spare tire to carrier bumpers.....or hood bumper. :think:
Has thanked: 12 times
Been thanked: 36 times
Post by sleepyzzz »
those bumpers have the wedge shape to jam against the floor and bench at a 45 degree angle. i wish you luck finding a source, but doubt that there is enough rubber in a crutch tip to shape it before hitting the hollow part that slips over the leg. could something be added onto the tip to make it work? i would look into that if i needed a pair.
1967 SPL 1600
2013 Nissan Rogue
2001 Nissan Sentra SE R
Has thanked: 38 times
Been thanked: 30 times
Post by antiquecyles »
For those of you like Bosque who are crafty, go to lowes and get this (item # 881324) from the specialty rubber drawer in the Hardware dept. It can be shaped/drilled out to slip over the leg tip. You could put a 90 angle by using a grinder or cutting it. Go to Lowes.com to see it
Has thanked: 104 times
Been thanked: 175 times
Post by Swerve »
I'm sure its in my 73 thread, I used rubber feet from chairs, cut them down to 45 degrees and done
Top right
Swerve wrote:I'm sure its in my 73 thread, I used rubber feet from chairs, cut them down to 45 degrees and done
Top right
it cant be that easy... :shock:
thanks for the post
I was off yesterday and decided to try the rubber pieces I bought at Lowe's. Talk about easy! It took about 2 min total.
Using the Hillman rubber plug
drill out 3/8" center hole about 1/2" deep.
using a dremel with a cutting tip, make a inner notch about 1/8" deep, 1/2" from edge.
put a couple 90 degree angle cuts at opposite end using razor blade.
Done. (Could use contact cement or adhesive as well.)
note...I didnt measure anything and it worked perfect. Having the old rubber foot nearby is a good reference.
Post by sleepyzzz »
nice job
1967 SPL 1600
2013 Nissan Rogue
