Carb/intake part??
- Has thanked: 97 times
- Been thanked: 568 times
Carb/intake part??
Ok Patrolers.....what is this? It was bolted to my intake manifold. I know I've seen it somewhere before but I couldn't find it in the part catalog. Any help?!!?
- Has thanked: 7741 times
- Been thanked: 2482 times
Re: Carb/intake part??
Bolted to the intake manifold? Thats a new one.
That looks like it is the vacuum advance for a water protect distributor; it's supposed to be on the side of your distributor. It looks like the actuating stem is missing though.
- Has thanked: 652 times
- Been thanked: 632 times
That actually bolts to a metal bracket which bolts to the manifold. It has a plunger that contacts the carbureator linkage. Im not sure why they put these on the patrol, but when you hit the throttle the plunger extends, and when you let off the throttle the plunger contacts the carb linkage an slowly retracts to let the carb go back to idle at a controlled rate.
i have heard them referred to as IDLE CONTROL STEPPERS
Hmm.... well this one seems to not function as it doesn't move in or out. Do I need it and if so where should I look??
You don't need it. Toss it over your shoulder for good luck.
- Has thanked: 17 times
- Been thanked: 50 times
Or if you have a mate doing a rebuild of something just throw that in with the parts and see what he does when he's finished and that thing's left overRiverPatrol wrote:You don't need it. Toss it over your shoulder for good luck.
Topless is the only way to go
Rolly wrote:Or if you have a mate doing a rebuild of something just throw that in with the parts and see what he does when he's finished and that thing's left overRiverPatrol wrote:You don't need it. Toss it over your shoulder for good luck.
