The previous owner had it sitting for several years and had never gotten it running. The owner before the PO had swapped the P40 engine for a Chevy 292. I believe that the transmission and all other running gear are original.
I was told that the carb needed to be rebuilt and it needed brake work. So far I replaced the brake master cylinder, got new tires, rebuilt the carb, drained the bad gas from the tank and replaced the fuel filter. It runs very well now but the clutch is pretty sketchy so its not exactly roadworthy.
I am trying to decide where to go from here with the transmission. I would love to have a higher top speed and it looks like the options for getting there are a 5 speed swap or possibly a theoretical overdrive setup for the existing 3 speed. I saw RiverPatrol's post over on ratsun.net which is what got me over to this forum.
Does anyone have a suggestion on what route to take for attaining a higher top speed? I am only trying to get to the point where I can cruise on the freeway at 65.
Thanks for any input. Here are some pics of my patrol (I also have a 73 510 shown in one picture):
Thanks for dropping by. Make yourself at home and take a look around. You'll find plenty of literature to keep you busy (and suck up your bandwidth) for a while.
