Missing clutch cover?
Has thanked: 49 times
Been thanked: 141 times
Post by ckhorne »
I was under my Patrol, looking at some things, and noticed a rather large, conspicuous gear hanging down, exposed. I think this is part of the clutch assembly, but wanted to see if I can get someone to help ID it.
I've added two pictures, but I'm not sure they'll help much.
Looking at the parts diagram, I think I'm missing a clutch cover (#9 in the diagram)- can anyone confirm?
Re: Missing clutch cover?
Yes I believe you are correct. That cover (and the oilpan) is off mine right now and it looks exactly the same. The gear is the starting gear that wraps the flywheel onto which the clutch assembly bolts. It's easier to see when it's hanging outside the Patrol! Here's a picture of mine...
Has thanked: 149 times
Been thanked: 310 times
Post by G60michael »
my 72 is missing it as well, I've got a contact to get a few of wrecks, if I got a spare and you haven't found one, let me know :)
Has thanked: 12 times
Been thanked: 36 times
Post by sleepyzzz »
i wonder if you dropped it while four wheeling? that makes me want to pull mine in the garage and check for loose bolts.
1967 SPL 1600
2013 Nissan Rogue
2001 Nissan Sentra SE R
Post by ckhorne »
I've only driven it home from where I bought it; it's been sitting in my garage ever since. I suppose it's possible it fell off in the hour that it took to get home, but it's more likely that it was like that when I bought it.
Has thanked: 7718 times
ckhorne wrote:I've only driven it home from where I bought it; it's been sitting in my garage ever since. I suppose it's possible it fell off in the hour that it took to get home, but it's more likely that it was like that when I bought it.
You're probably right. When you go to put the new one on, you'll notice that it is wedged in there pretty tight. There isn't much chance of it just falling out, even if the bolts were missing.
Before you get the new cover, it would be a good idea to determine what bolts you'll need to put it back up there. As I recall the bolts are a standard thread size but they are pretty short, shorter than what you can easily find. I think I have actually cut down bolts to make them fit correctly.
Post by ckhorne »
Good to know. I think G60michael is going to be able to hook me up with both the cover and the bolts.
It's awesome to find a site like this, where everyone is willing to go out of their way to help each other! :clap:
