lifting a kl60
lifting a kl60
HEy guys anyone lifted there p-troll. I am looking for a cheep way to get a few inches. Will a universal shackel kit work for front and rear. what are some other options. I would like to get 33's under it. 31 fit right now but not sure how they will do when it articulates. open for sugestions how about a body lift of some kind? thanks alot
lifting a kl60
I think you can go with as much as a 2" body lift. I dont know if you could fit more, and I wouldnt want to. Its bad enough that the Patrol's frame already shows.What I would do is remove the inner spring hangers, and make longer ones out of some 1/4" plate steel then add longer shackles.Another, option, though rough, is add-a-leafs. It would give you some lift, but it would make your ride rough.You could SOA your Patrol, but it entails alot more work...Somebody, awhile back, posted pics of where they had wedged some coil springs between the axle and the frame.Hope this alteast gets you started on the right track.
